Watch of Today
mk3
4 hours ago, balaton said:
Blimey, I see what you mean.
What you've got there would appear to be two French-made Framelac pin-levers, a movement maker about which very little seems to be recorded. I've attached an image from the Uhrforum.de of the jewelled-lever FR 304 for comparison of the bridge configuration (similar) and the shape of the balance cock (identical).
Thanks for the info. The Rodeo is remarkably similar to this.
https://www.uhrwerksarchiv.de/movements/c/crc/crc-960/
.. but perhaps is closer to this.
https://17jewels.info/movements/c/crc/crc-860/
It has the cruder balance, but a different "shock" spring arrangement as opposed to what looks suspiciously like glue on the example here.
The "LiJac" is certainly from the same stable, but even simpler in its construction.
Well, that's pretty convincing and I think you've nailed these oddities!
I certainly don't have any examples of them in my collection of old nonsenses. Neither, obviously, does Ranfft, so well done Chris Lorenz.
Cheers.
Edit: This in response to @AndyHull last posting
Edited by balaton
add text
Long time since I popped a pic of a watch here .. but today I thought I'll hang a noname watch around my wrist.
The Purple danger has a modified 2824-2 raving under the hood, the date function har been removed ;)  .
An "almost new" HMT Janata today. It did require a service and a bit of a polish to get it to this state, but I'm pretty pleased with the result. This one appears to be completely original.
I have a bunch more HMTs waiting in the wings to join the 404 club, I'm just a little short of that all important ingredient "spare time" at the moment. I'll post the rest when I get a chance to work on them.
Love the art deco numbers [emoji106]
3 minutes ago, ro63rto said:
Also waiting in the wings (pun intended) is this near identical white dial version.
I've not had a chance to work on that one yet, but it is probably going to be the next victim on the healing bench.
Today, a 38mm Aidix, attributed to Rene Brandt and running on an unusual variant of the 14’’’ 15j ETA 853.
So far, the earliest confirmable date of brand registration recorded has been 1952, but I would have tended to put this particular example in the previous decade.
Regards.
Regards.
Nice sunburst dial, and I've always preferred sub seconds in a dress watch. The movement reminds me of the AS 1130
J
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
