Watch of Today
mk3
On 6/8/2019 at 10:48 AM, ro63rto said:
Engineer today
New OEM crystal gasket and crystal
Still to do - refinish bezel, refinish bracelet, find or make bezel filler ring
2I4T0lb.jpg&key=e4efa397a0050d583419126dd7da8884a3b6eb515ba6d481c43010d392fb2df0
I suppose You could refinish as suggested.I think it looks great as is.
Today I barely managed to resist the urge to don my ten gallon hat and chaps and head off to the pub with no beer
The "Rodeo" is getting a ride round the range on my wrist today.
It is actually pretty well behaved in terms of keeping time. That mystery 17 jewel french movement performs about -10 to +15 s/day hovering near 0.3 ms and managing a fairly healthy 287 degrees of swing at 21600bph.
The bizarre transparent burgundy case sometimes makes it appear that the crown is backlit by an LED.
A strange but interesting addition to the 404 club collection.
7A28-7040? Got one of those in Hong Kong back in '83.still have it.but it isn't running.
Yup. Dec '82 so quite an early one.
Unfortunately got just the head. It's on a SS bracelet I got off eBay for £10.
It went off with a few others to George Clarkson in Berlin to perform his magic.
Is this a fancy watch branded? I mean, I haven't heard the brand Depraz anytime before. So I was just wondering if that's genuine with good quality.
The D logo looks like an old font used by sports company Donnay [emoji1]
"Depraz" name looks to have been registered in 23/05/1986
I searched Depraz a few weeks ago and could not find any reference. There was an ad on ebay for a watch. It was priced £10 and did not sell.
I found a lot of ref to Dubois-Depraz which if I remember right was more of a high end movement. So I came to the conclusion it was a cheap knock off. Can't confirm that though.
22 minutes ago, noirrac1j said:
Are those decorative CORK inserts?!?
Joe
I think it is all ceramic. I believe the term is "Fat Lava".
This has apparently become collectible, so if you have any garish pottery from the period, you may find it is worth more than you thought.
Incidentally, some of the glazes used contain uranium, which is unsurprisingly, mildly radioactive, so grab a nice red or green example, and you have something to store all that used radium and tritium lume in. Collect enough and you can get yourself on an international "watch" list of an entirely different sort.
I did a full service on a 70's Depraz a few weeks ago.
Details on my blog if anyone is interested.
Link in my signature below.
Thank you Marc. That's more info than I found.
So it is a separate company to Dubois Depraz but not a copy
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
