Watch of Today
mk3
6 hours ago, Johnnie said:
And today it's another Seiko, the first watch I really "got into" and repaired and finished. Thanks mainly to the excellent guidance I received from fellow forum members.
Really clean example of this watch ,...Nice work Johnnie .
They say , "like minds think alike" , ........That may be true .
1493869352_ScreenShot2019-05-17at10_58_55PM.thumb.png.fb6e7da54808a0f87eaec1fcadb9ae43.png
659141730_ScreenShot2019-05-17at11_00_54PM.thumb.png.e55b6a597f10b7c1b4d812b79a02e996.png
I'm wearing one of the Timexes today. It looks reasonable on the time-grapher, but gained about three  minutes left face up on the desk over 24hrs, so I decided to see if it was better behaved on my wrist before diving in and fiddling.
The strap is probably from roughly the correct period, but I'll most likely substitute a leather one.
These springy old bits of metal tend to wear out the lugs, and since this old fella is pre 1962, probably mid to late 1950s I feel it needs something gentler to keep it company. I also need to check the junk pile to see if I have a suitable second hand for it.
The Lorus went on the other wrist shortly after I took this pic, so that I don't scratch either of them by bashing their heads together.
Edited by AndyHull
This one just came off the work bench.The progeny of two movements with different issues.it has more positional variation than I like,but it is shuffling along pretty well.genuwine leather strap from the Wal-Mart discount bin set me back a whole 99 cents
"Andrew The Hatton" from the mid 1950s finally got a little of the much needed TLC I promised it, when I was waiting for it to arrive back in December. Sporting what I think is a Amida caliber 553 17 jewel variant, it is a bit of a rarity I think (rare ≠ valuable however). I'm probably wrong however, so any better guesses are welcome.
It obviously still needs a crystal, and got a more thorough scrub and polish after I took these pictures, as I clearly didn't make a perfect job of it the first time. The marks on the dial were there when it arrived, and I haven't dared to even think about cleaning the dial yet. I'll probably leave that well alone.
Another non-runner, needing the usual clean and service. It seems to be running reasonably fine around +40s/day, although the error is a little high for my liking at 3ms or so. I'll wear it and keep an eye on it for the next 24 hrs just to be sure it has survived my servicing efforts unscathed.
I thought you might like to see my patented case back opener. aka a short length of carpet tape. This stuff is scarily sticky, so it makes an ideal substitute for the no doubt very expensive bespoke opener that adorned the shelves of the original service centers back in the day. It also doesn't leave any sticky residue. If this hadn't done the trick, I was going to superglue a nut on the case back, another useful trick to avoid marring things when you don't have the custom case back opener you require.
If it keeps ticking for the next day or so, I'll spring for a crystal for it (which may represent a doubling of the cost of my "investment" :D).
Edited by AndyHull
This little cocktail watch was an eBay non-runner. I cleaned it, oiled it, replaced the mainspring and worn barrel arbour, fixed a bend in the hairspring, reduced the hole size in the minute hand, new crystal . And I also did some dynamic poising. I've got it running within 15secs per day in all positions. It's by far the tiniest movement I've worked on. Everything else seems comparatively huge now!
The only annoying thing is I accidentally rubbed off the Omega logo whilst attempting to clean the dial :growl:
I love the hasty engraving  seventeen  1 jewels
I was thinking about that, I suspect they had a bunch of rotors, all inscribed in bulk "           1   Jewels Swiss " which then got "Twenty One 2" or "Seventeen   7" inscribed on them later, depending on the movement they were destined for.
Alternatively this was a bit of a Friday watch.
It is still ticking away nicely after a slightly shaky start (it stopped soon after I put it on, so I manually fully wound it). The amplitude has picked up a bit too, and the rate dropped to -50 from around -40 - the beat error has also decreased to about 2.2ms, so it looks like the lubrication is starting to settle in.
Edited by AndyHull
These tiny movements can be a real challenge. As to the dial, it is all too easy to do. I cleaned a nasty green mark off one and settled back to admire my handiwork, only to then realize I had also removed part of the word "Swiss" :wacko:
Edited by AndyHull
6 minutes ago, yankeedog said:
I am just amazed at the quality of work that can be done with a hangover.
Surely that would be a Monday morning watch. A Friday one would be after a liquid lunch, so the hangover hasn't kicked in yet.. not that I would know of course... :P
What size (diameter) is the dial? I might have a spare if you want to have another try ;)
1978 Timex Mercury - I finally got this to behave itself.
I could possibly go chasing a little more amplitude, but from >+3600 s/day with a beat error of >14ms and an amplitude of around 140 fully wound following the first cleaning session  to +/- 5s/day, a sub 1ms beat error and an amplitude hovering around 230 degrees is almost good enough to keep the OCD at bay for the time being. Just as well really as I was going cross eyed staring at that hairspring for so long.
Except of course
there are still those little scratches on the crystal, (which I have grossly exaggerated by holding the watch at just the right angle to the sun here). Time to do a little more light polishing I think.  But first, I think I'l wear it for a few days, just because I like the look of it, and I'm bound to add to the scratches while wearing it, rather than lessen them.
Its amazing what you can do with a little patience and a couple of sewing needles. The hair-spring-de-nardelling was done with the balance still in the watch, as it is far too much of a faff to take it out, and you run the risk of "fixing it worse" and/or loosing the hs retaining pin if you are not careful.
Edited by AndyHull
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
