Watch of Today
mk3
Its a blue dial day today.
I'm wearing a Nino 17 Jewel swiss, while assisting my wife with her patchwork quilting designs. It had a slight rust issue when it arrived a few months back, but it is ticking along nicely now. I even restored the brushed case finish.
Manual? I guess ST caliber.
The case, caseback and dial look original, but I'm suspicious that the caliber may not be. Partly because of its condition, and partly because the movement holder looks to have been hacked about a bit. This is what it looks like after some fairly major gunk and rust removal. There is still some remaining evidence of corrosion as you can see.
St movement, work horse, powered , fortis , camy among many . If dial feet are original and fit the movement, the two belong.
You have to hand it to the boys in India . Where else can you get a GENYOUWINE Swiss watch serviced and delivered to your door for under twenty dollars ! Perhaps from a NYC street vendor, but nowhere else !
49 minutes ago, m1ks said:
Another Indian eBay franken dial swiss.
A genuine Henri Sandoz in fact. Lol
I love the dial colour on this one.
Very.. err.. purple...
You appear to be having a bit of a Local Hero moment, I was just waiting for Jenny Seagrove to emerge from the waves in the background, to come and admire your purple heather tartan themed Sand-oz.
I'm going to hazard a guess that the movement is a no name ST 96 variant, second guess would be an HMT 0231 with Sandust inscribed on the bridge where it used to say HMT. Go on... give us a peek inside, curious minds want to know.
Jenny Seagrove can come and admire it anytime.
Here's the case back to prove it's genuine osity! Plus the listing said it was vintage and genuine. :)
I'll get a movement pic soon as I can be bothered to get my case back knife
Edited by m1ks
Forgot to add picture doh
1 hour ago, eezy said:
Another Henry S. Don't know if the dial is genuine or not.
I'd hazard a guess that yours is more genuine than mine. The snap on back is acid etched on mine by the look. Very well done mind you, but not engraved.
That's a really nice case shape on yours.
The case is unmarked, looks new. Has a screw back also. It's my ''play with'' watch as the movement was knackered.
The case bears a startling resemblance to the "Nino" above.
Here it is again, on the left, along with the franken-zen and a little Richo (arguably the most authentic of the three).
It does, yes, even down to the lightly brushed finish on top of the case.
Is the Nino a screw back as well?
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
