Watch of Today
mk3
Its a blue dial day today.
I'm wearing a Nino 17 Jewel swiss, while assisting my wife with her patchwork quilting designs. It had a slight rust issue when it arrived a few months back, but it is ticking along nicely now. I even restored the brushed case finish.
Manual? I guess ST caliber.
The case, caseback and dial look original, but I'm suspicious that the caliber may not be. Partly because of its condition, and partly because the movement holder looks to have been hacked about a bit. This is what it looks like after some fairly major gunk and rust removal. There is still some remaining evidence of corrosion as you can see.
St movement, work horse, powered , fortis , camy among many . If dial feet are original and fit the movement, the two belong.
You have to hand it to the boys in India . Where else can you get a GENYOUWINE Swiss watch serviced and delivered to your door for under twenty dollars ! Perhaps from a NYC street vendor, but nowhere else !
49 minutes ago, m1ks said:
Another Indian eBay franken dial swiss.
A genuine Henri Sandoz in fact. Lol
I love the dial colour on this one.
Very.. err.. purple...
You appear to be having a bit of a Local Hero moment, I was just waiting for Jenny Seagrove to emerge from the waves in the background, to come and admire your purple heather tartan themed Sand-oz.
I'm going to hazard a guess that the movement is a no name ST 96 variant, second guess would be an HMT 0231 with Sandust inscribed on the bridge where it used to say HMT. Go on... give us a peek inside, curious minds want to know.
Jenny Seagrove can come and admire it anytime.
Here's the case back to prove it's genuine osity! Plus the listing said it was vintage and genuine. :)
I'll get a movement pic soon as I can be bothered to get my case back knife
Edited by m1ks
Forgot to add picture doh
1 hour ago, eezy said:
Another Henry S. Don't know if the dial is genuine or not.
I'd hazard a guess that yours is more genuine than mine. The snap on back is acid etched on mine by the look. Very well done mind you, but not engraved.
That's a really nice case shape on yours.
The case is unmarked, looks new. Has a screw back also. It's my ''play with'' watch as the movement was knackered.
The case bears a startling resemblance to the "Nino" above.
Here it is again, on the left, along with the franken-zen and a little Richo (arguably the most authentic of the three).
It does, yes, even down to the lightly brushed finish on top of the case.
Is the Nino a screw back as well?
    • I think if you want to play Billy big b.ollocks then you have to have something up your sleeve, anyone that knows how to fight, plays dirty. Lets face it a lot of folk that voted for Brexit just rolled uk their sleeves to say up yours EU hoping for good changes. We have idiots for leaders and probably none of them clever enough to clean the shitty stick they were given. I didnt vote, what will be will be.
    • I voted leave too, my reasoning was the the EU is undemocratic, no elected officials. I don't regret it but I  am sad that both sides acted like petulant toddlers.  Shameful.  I'm not on other forums but if I was and left this site, would you shun me? Of course not, we aren't petulant toddlers.
    • This is a type of tool that may be suitable to remove the bezel - though note that I'm pretty sure the watch should be face down - not face up, as in some of the photos of these tools on amazon & ebay! If you try one one of those, put the movement screws back in first to avoid accidents. https://www.amazon.co.uk/Removal-Professional-Remover-Watchmaker-Diameter/dp/B09XCH4QVN?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A296NCMMFVXSDN&th=1
    • Hi, I’m constantly asking my wife to help me with removing the stem in order to complete casing. To expand, this is not a challenge for me when the setting lever is secured by a screw (older calibers). However when the setting lever is attached to a spring loaded setting lever axel, like on more modern calibers, I simply don’t see how to apply enough pressure on the button to get the stem out short of putting the movement face down with the dial and hands attached, which I’m loath to do in order to avoid damaging the dial/hands? what technique should I be using? thanks
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
