Watch of Today
mk3
15 hours ago, yankeedog said:
Thanks guys...I wouldn't buy anything that didn't show the movement.I would think of them more as raw material..a case.a dial ,hands.that sort of thing. The cases do look like a decent grade of stainless steel .
Never buy a watch from the bay unless the movement is shown--this is a GOLDEN RULE! The only time I've broken this rule have been the few times that the watch dial, hands, case and everything else look soooo good, that it would still be worth even it if it contained a rusted bottle cap inside.
J
5 minutes ago, Nucejoe said:
I don,t have a valid answer. I think some of these massey fergusons that tic here can guzzle either one.
Ha ha ha. Its like the "Regular vs Premium" gasoline discussion. They will all work in the engine , but what happens in the long run?
God knows, I assemble most of what goes in my collection without oil, beleiving If not in use a watch keeps better oilless.
0w20 synthetic motor oil. I could by expensive watch oil..if I bought expensive watches.viscosity is similar to   moebius 9010. It's synthetic..so it doesn't break down.it doesn't turn to sludge.It lubricates over a wide range of temperature.as for WD 40.it's not a lubricant.it's primary use is as a penetrating oil and for water displacement.I have been told it's fish oil.I believe it.Because I have never seen a rusty fish.
Really?!? Wow that price differential is extreme to say the least.
Mobil 1 full synthetic, 5 quarts on sale for $22.88,  works out to $.004 per mL
Moebius 9010 synt-a-lube  is 27.95 for 2mL, which works out to $13.97 per mL
:phone:
1 hour ago, Nucejoe said:
Over here we get watch oil said to be made in India, some say its fake pakistani passed as Indian make.
Ironically it may in fact be Chinese, or even... given that Iran is a rather well known producer of crude oil, home grown.
Which reminds me somewhat of the irony of living and working in Scotland, which is also a major oil producing country, but where I pay more for my Diesel than they do in London. The commonly spouted excuse being "transportation and manufacturing costs". I can see the flares from the Grangemouth petrochemical plant lighting up the night sky from here. I somehow doubt if the same is true in the home counties of England.
However back to the oil.
I suspect SAE 75W-140 gear oil would be close to Moebius 9010, in terms of both viscosity and longevity, so assuming you have no other option, gear oil is almost certainly 100% better than nothing, and about 99.99% better than WD40.
Today's watch, fresh from the healing bench is a Citizen 21 Jewel "Parawater" (so most probably from 1971). It arrived looking a little miserable, and struggling to tick.
I took a quick look at it shortly after it arrived, and got it going, but I wasn't 100% happy with it, so it received a little more TLC, and is going considerably better. I might be able to get the beat error down a fraction more, but since I decided to quit while I was ahead.
The date changer is also working correctly now too.
Now that it is running reasonably well, and has survived a day on my wrist without complaining, I'm might see if I can bring back a bit more of the original shine.
I have tried gear oil.It's a bit thick and the movements tend to run and stop.I have tried automatic transmission fluid.It is a bit thin and tends to find its way to the hairspring making the watch run fast.0w20 seems to be the sweet spot. I am not saying it is better than moebius. But you have to admit that besides being masters of horology the Swiss are also masters of hype. They have got us paying how much for a little vial of oil? Now don't go using it on your Rolex...but if you have an old  vostok or hmt laying about.give it a try...
I'm with you there. Used engine oil works on old alarm clocks.. but I wouldn't recommend it.
But yes, there needs to be some pretty sophisticated technology going on in those Swiss oils to justify the price, and I'm not sure that there actually is. Admittedly you don't need much, but none the less per ml it is pretty pricey. I'm not saying it is snakeoil, but...
1 hour ago, yankeedog said:
AS 1187 movement generic Hong Kong case.Dial decal printed on IJP. Franken for sure,but a fun experiment in spare parts.
Looks very convincing. How sharp did the inkjet decal turn out? Where did you borrow the design from? It looks pretty good from here.
Edited by AndyHull
The IJP decal wasn't particularly sharp.but it is legible. The design is US military a17. Used during the Vietnam era on military issue watches.it was scoured off the internet and modified a little with the Microsoft paint program
Edited by yankeedog
Content
Just for fun, I stuck the Roxedo on the time grapher.
Bear in mind, this is a pin lever, which I replaced the balance and fork in,  back in November with one from a scrap movement. It also was cleaned and adjusted. There is no simple way to adjust the beat error, so back then, I just left it as it was, and set the rate, rather than risk fiddling with the hairspring.
This is how it looked when it arrived with the broken fork and dodgy balance.
Today all I did was  grab it wind it and stuck it on my wrist.
It is far from perfect, and certainly wouldn't win any prizes but for those doubters that say pin levers are rubbish, unreliable and don't last, this thing has been clacking away like an old alarm clock, probably since the 1970s or perhaps even the late 1960s, judging by the style, and is still keeping reasonable time.
I'm pretty happy with those numbers.
There is really nothing wrong with pin levers.They were built to satisfy a market segment. I think they suffer more from shoddy cases than anything else.Generally they were poorly sealed and allowed both water and dirt to enter. Which is a bad recipe for any watch regardless of construction..Lack of shock proofing was also a problem.
On 5/3/2019 at 5:47 PM, AndyHull said:
An old favorite, the Roxedo EB 8800 pin lever is back on my wrist today.
I like the simple uncluttered elegance of the design of this piece. It make a very readable, robust and comfortable daily wearer.
My favourate dial, dress watch and silver color. Enjoy it andy, most popular color too.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
