Watch of Today
mk3
9 hours ago, AndyHull said:
A fine looking watch. 1968 was a bit of an eventful year the Vietnam war was in full swing, and Apollo 7 was launched, and somewhere in the world, your Timex came off the production line, and may well not have seen a service between then and you opening the case back.
Yes, I do think of watches as not only telling of time but as piece of time as well.  Where have they been?  Who wore them?
Maybe witness to some memorable moment in history?  Perhaps this one even past my way at some point in time?
Nice one JerseyMo  thats exactly how i think of the clocks and watches I work on, little pieces of history. most of the clocks in my collection have been restored to working order the cases still contain the dings and dents they got in life, missing bits of the cases are made and fitted so its complete but not made to look like new again Dials are treated the same , I know where they came from and in most cases know who owned them.
I agree , I see engraving on the back and it sets my imagination into motion . I didn't used to feel that way , and either tried to remove the inscription , or looked for another case back .
But after seeing so many now that say "Love Always" , or "On your Graduation 1960 " , or "Congratulations" .
I now start to see a side road off of the usual business of watch Collecting .
This great Hobby has also helped teach me patience , given me Pure Pleasure after a completed project , and lets me escape for a while into a world of quiet , beautiful parts and pieces , and the  satisfaction of having a Nice timepiece on my wrist .
Yep! no technology just your hands and brain working together.
46 minutes ago, AndyHull said:
Nice, is it purely electric (i.e. contact spring), or transistorised?
Hi, No, BW is powered by coil in MG field. Good quality movement like eta ,Rado parts in it, I think 17 jewels.
Edited by Nucejoe
Ya, purely electric.
The blue/green "Japan Made" Frankenzen is getting an airing today.
It polished up quite nicely. The timeless sands of India and the glue stains are gone and it is now running fairly well (around +7 to +15 s/day).
I'll keep an eye out for a less "interesting" dial, and if one comes up, I may return it to a more conventional look. For the time being though, I'll just enjoy its quirkiness.
Edited by AndyHull
1 hour ago, yankeedog said:
I often wonder about  watches like that from India.
noirrac1j  is correct . You get plenty of glue and possibly a surprise movement in a lot of those watches . ....
Although the exception to the rule is that if you need a part , you can get a whole watch for close to the same price as the part . If the correct movement is in the watch .
One more thing , the caseback may not necessarily go with the case it is installed on . Having said that , I have been lucky more then half the time with the correct part .
I totally agree, they are a complete lottery. However if you buy them with the full knowledge of this, and don't get carried away with the bidding (none of the ones I've picked up cost more than the magical £4.04), then you almost can't go wrong.
Bid low, and bid on a bunch of them, and you are almost certain to get one at pocket money prices eventually. I can't even source a cheap strap locally at that price.
I do have a "Seiko" with an Allwyn movement, and I also picked up one that had the dial rattling around loose inside, 'cos the glue they had used in place of dial feet, had come loose, but if you need a balance, mainspring or some other part, or even just a good stainless steel case, they are often a way cheaper source than any alternative.
Be aware though that the "Fortis", and other "Swiss" brands are often HMT, Citizen, Seiko or Allwyn watches with franken dials.
If it comes from India and looks like an HMT, but it says it is a "Favre Lueba" or a "Rare Fortis", then it is almost certainly an HMT with a franken dial. Bid as if it is a franken.
2 hours ago, yankeedog said:
Thanks guys...I wouldn't buy anything that didn't show the movement.I would think of them more as raw material..a case.a dial ,hands.that sort of thing. The cases do look like a decent grade of stainless steel .
You're Welcome Yankeedog .  To expound on what you just said about the parts or raw material .
I think you understand what fellow members are saying based on experience . The value is there for raw parts .
In my experience , the glue I mentioned before is mainly to hold the dial , and in many instances , also a dial spacer that came from anybodys guess . The glue is used to hold a dial because usually the dial feet are gone .
I have used the cases and associated parts with some success
Besides India there is Latvia. This 2214 came from there.Running nicely on synthetic motor oil.
Oh jeez...I've had my share of movements that smelled like WD-40, but not automobile engine oil!
Its likely quite difficult and/or expensive to get Swiss Moebius oils in India and Latvia, so they've gotta be resourceful.
J
J
Over here we get watch oil said to be made in India, some say its fake pakistani passed as Indian make.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
