Watch of Today
mk3
Regarding the previous questions...
Correct, in some degree, however heat, in and of itself is not the main cause of solar cell degradation, as I understand it at least not the heat from the generally low level of IR and other wavelengths that don't have enough energy to excite the electrons in the silicon.
According to the article I linked above, the problem is as follows...
Quote
Crystalline silicon modules located in extreme climates showed high degradation rates. For very cold climates, panels subjected to heavy wind and snow loads suffered the most. On the other hand, panels in similar climates that were installed in a facade, eliminating the snow load, had very low rates of degradation. At the other extreme, panels in desert climates exhibited large decreases in production over time - close to 1% per year - mainly due to high levels of UV exposure. Panels in more moderate climates such as the northern United States had degradation rates as low as 0.2% per year. Those panels could retain 96% of their production capabilities after 20 years.
So the issue is multivariable, but the principle issues that contribute to the degradation of PV panels are the mechanical and heat/cold cycle stress induced structural effects (which leads presumably to increased electrical resistance and poorer light transmission within the active layer of the silicon), and the effects of high energy photons ((UV and above),  as opposed to IR light effects, which cause similar damage, but via slightly different mechanisms.
My understanding is that very high energy particles and UV cause the coating materials to become damaged too, and this hampers their ability to transmit light to the active element (the poly-christalline silicon). So we have heat/cold/mechanical and UV stresses which damage both the structure of the silicon, and probably equally importantly, the clear protective coating, causing both to be less efficient.
A wristwatch however is much better protected from the elements, so I suspect these effects cause at least an order of magnitude less stress on the panel. Unless you are something like, say a professional camel racer, or some other profession where you and your watch spend most of your time subjected to high levels of sunlight, in which case you should be  taking better care of yourself and your watch anyway.
In answer to photon energy question.
Quote
The energy of a photon can be modeled by the equation E=hf, where h is a constant and f is the frequency.
Since all light travels at the same speed, roughly 3x10^8 m/s, and v=(lambda)f, where lambda is the wavelength, we can derive that f=v/(lambda) so E=hv/(lambda), by substituting for f in the first equation.
By plugging in for our known constants we can see that wavelength is the only variable in determining the energy of the photon, and because it is inversely proportional, a larger wavelength will result is less energy, while a smaller wavelength will result in a higher energy photon.
This makes sense because high energy light such as ultraviolet light has a much smaller wavelength <400nm compared to visible 400nm-->750nm and infrared >750nm light.
We are however getting pretty far off topic for this thread I suspect.
Edited by AndyHull
15 minutes ago, ro63rto said:
Had this Aeromaster on today
Ya5UV4H.jpg&key=ac2fe6ae61c5451cb57a06f6ed65e7b9e844d7a0a62c504b81c392c329d745a8
Very nice, it looks immaculate, and so does the old one pound.
Are we going to have to re-introduce the £1 note again, as post Brexit currency because of Boris's Brexit bonanza,   or will we perhaps need a few more zeros on the bank notes instead? :P
When they first withdrew the Bank of England one pound notes, Scottish ones were still legal tender as I recall, with the result that if you presented one south of the border, you would tend to get change of a fiver.
Hi Johnnie ,  are you going to do the crystal change yourself ?  If so do you have the tools and skills for this procedure which may include measuring the old crystal and case among other things to purchase the correct size you will need to order and install your new crystal .
I would look at a few good youtube tutorials to help . Good Luck .
4 hours ago, Johnnie said:
Today's offering is my Orient watch, runs perfectly,,,, but needs a new crystal as this one is cracked and burnt ! Done before my ownership. Any suggestions where I can got one would be appreciated.
Hi again Johnnie , ...Do Look at the youtube videos first....
I can't tell if your watch has a removable bezel as that would be a small clue . Some crystals are held in by the bezel . Some are pressed into a rubber or nylon crystal gasket . Some are held in by a tension ring [armored crystal ] , that is either silver or gold colored ,...Etc .
Having said that and trying not to confuse things , you don't have to get a crystal that is a branded original . The tension ring type is an example . Measure your old crystal and case seat with a micrometer and order the size and ring color you need .
  In the United States I use Esslinger.com , or Jules Borel . In Europe , Cousins is the go to place but there are many more resources so you have to do good searches .
A new crystal isn't something that you would likely need to purchase from Orient. Remove the old crystal and measure it. On your side of the pond, Cousins UK will undoubtedly carry exactly what you need and likely at a substantial discount over the same item from the manufacturer.
Hi again Recardo& TexasDon, looking at the watch it doesn't look like the bezel comes off so I think the movement needs to be removed before the crystal can be removed. The crystal seems to have been burnt as well as cracked, also the dial itself seems craved and crinkled. The colour is there but looking at it there seems to be a clear coat that's lifting, possibly through heat. It works well and is keeping time very well so that's good. With a change of crystal and possibly a replacement dial it would be a nice old watch and I would like to save it. I will try and post better photos if I can. Many thanks for your help.
These Orients came in two sises, give OD. Genuine Orient crystals are rare, mass produced generic ones are slightly of inferior quality and do get passed on as genuine on ebay. You would know the difference if you examine two new ones side by side.
I am not paricularely fond on seiko5, about forty of them found their way into my collection. Here is one I like and even wear.
Got it used, didn,t run good, the seller a friend chewed on my nerve that I should buy it, since I can fix it and he has had no luck dispite paying repairmans couple of times.
It came with a 611*  movement. No fault was noticable just took a nap at midnight when I was sleep.
I ended up replacing the gear train bridge with one out of 6139, interchangable.
Runs happy even when I am sleep, better than 33 hrs, winds fully in about an hr on wrist.
Hi NuceJoe, 44mm X 42 X 14.5 crystal measures 38.5
Edited by Johnnie
Added crystal measurement
The crystal on your watch dose not magnify day/ date. Shouldn,t it?     I am not sure from the picture of your watch, if it has a tension ring. I bought and installed one, the envelope says 390 but measure 38.5 mm, fitted perfectly, got magnifiers and tension ring.
No mention of all dimensions you gave, just says Orient 390-123 made by sternokruetz of Germany. The best I could find.
Not to worry about the price.
21 hours ago, Nucejoe said:
Second question, Didn,t you make the same mistake as marconi ? Shorter wavelength carry more energy in EM field.:P
And if the photonic energy exceed the threshold enough to energize two or multiple electrons, would it? Since the extra energy no matter how little, goes to forming a new photon, photons pop into existance don,t they?
Electron Physics, electronics, metallurgical....? Your decipline please.
Discipline is Electrical Engineering.  Mostly having to do with semiconductors but not professionally with solar cells in particular.  I was exposed to them in school though.
I was referring to wavelength relating to energy.  I do know that it's inverse.
Right, thank you.
Best wishes
Hi and thank you, no magnifier on my watch but not sure if it should have. Will Google it and see if it may have had one on leaving the Orient factory. Will look for the crystal you bought at Cousins. Thanks very much for your time and trouble.
Today I'm road testing the Gold Citizen Crystron that needed a bit of surgery a few weeks back. RIMG0614.thumb.JPG.7dee3530ff90f1a5ce7ab7d3b1bc3cfb.JPG
It was running a little slow, presumably because someone had been tweaking the trimmer capacitor on the pcb in the forlorn hope that it would somehow bring it back to life.
I used  tg in "Calibrate" mode to get a feel for how it was running as I adjusted the cap.  tg doesn't appear to be able to graph quartz watches directly.  Now it seems to be running much more like a quartz watch should.
I have an older citizen quartz watch. I am impressed by the construction of the movement, it starts and stops.. I am working up the nerve to work on it. Previous attempts at working on quartz movements have not been very successful. Large hands and brittle plastic are not generally compatible.
A light cleaning with a few drops of lighter fluid, and a very light oiling might be a safer bet, if it looks delicate, rather than a full strip down.
AndyHull wrote:
...presumably because someone had been tweaking the trimmer capacitor on the pcb
Neat watch.  Lowly Casio digital used to have trimmers, but I haven't seen a watch with one in years.  Does anybody make an adjustable quartz now?
I haven't see one with a trimmer in years either. I think they've been done away with. Pattern cutting is available on some models although that is rapidly disappearing too. As electronics circuit components and design have improved, the need for a periodic adjustment hasn't totally vanished yet but it's on the way out.
The need to trim the crystal with an external capacitor has largely been eliminated over the years.
If you look at the construction of the Crystron, made in 1977  and a similar quality modern quartz watch, you will see that pretty much everything is smaller, and (arguably) better engineered.
Modern watch crystals are much more accurately laser cut to tune them to a more precise frequency. They are also, generally more stable over their working temperature, and drift less over their working life.
Modern watch crystal, relatively speaking are not particularly accurate, when compared for example with ovenized crystal oscillators, but they are an improvement on their forty two year old cousins.
West end watch started production like eighty years ago, in calcutta India and mainly targets Asia, where it is a well known and liked brand,last I heard it had sold fifteen million or more pieces. Uses ETA and AS movements. West end watch was the first to adapt incabloc shock protection system. Then again about three hundered pieces found their way to my collection so I learned to like them.  Here is piece to start with , don,t run away please.
I wouldn't dream of running away, West End have made some very good watches, and they've actually been going for 133 years this year.
Look out for early Secundus models; some of them had unbranded Longines movements in them.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
