  • Similar Content
    • By HongJiho
      Hi my friends.
      I saw WRT video in youtube. It's so helpful to me. Thank you Watch Repair Channel.
      After watching video, I'm looking for watch repair oil and grease.
      I want know what oil & grease need to beginner.
      In addition, I want know what oil &grease used in video (7s26 repiar video).
      If anyone knew about that, help my work.
      I will very appreciate any information or links.
      Thank you to read my poor writing.
    • By Bethan36
      Hi Fellow People,
      Im reaching out as I’m currently learning all I can about watchmaking, and am working through the BHI distance learning technicians course, with my exam booked for May.
      I will need to service a quartz watch as part of my practical exam, and am learning about watch lubrication.
      A few months ago I found a great article that covered the technique for dipping and collecting the right amount of oil on the oiler, such as the speed and angle of the dip, however, I now can’t find it anywhere, no matter how much I search the internet
      Does anyone have or can point me in the right direction of instructions specifically on oil collection on the oiler?  As you will know there is lots on the actual oiling process but not the oil collection process.
      Any help would be greatly appreciated.
      Thanks
      Bethan
    • By east3rn
      Hello. I am considering buying a bottle of fixodrop and I found that there are many options regarding the quantity.
      Since I am hobbyist watchmaker, I don't service a watch very often.(Couple of them in a month)
      In this case, would it be okay to purchase the smallest amount of fixodrop(1ml)?
      One more thing. Is there anything else I should get to apply the fixodrop to my pallet fork?
    • By WorldPowerLabs
      Hello all,
      I'm about to service a Timex 260 electric movement.  It's running strong as-is, but I doubt that it has been cleaned or lubricated in its lifetime.  I do have the service manual for the movement and for most of the oil points, the SM calls for Moebius Synt-A-Lube, without specifying a product number (I intend to use Moebius 9010), but for the friction pinion the manual calls for "spreading type oil" (Woods AAAA oil).  I cannot find a cross-reference for this old Woods oil and most watch oils are, of course, specifically formulated to NOT spread...  so, I'm seeking advice and suggestions for a suitable oil to use on the friction pinion.  Also, if anyone thinks that 9010 is NOT appropriate to use for the various other points, please let me know.
      Thanks much!
      Ben
    • By Paul78
      Hi all, I'm thinking about investing in the set of automatic oilers available from cousins. They cost about 200 quid with the VAT, that's obviously a lot of money so just wondered if any of you use them and are they worth the money?
    • Have adjusted it like that. Also removed the jumper altogether to see if the disc would move more, but it didn't. I measured the diameter of the peg on the driving wheel and it's 0.3mm, is this the correct size?, to me the peg looks a little bit smaller then the other once I see pictured here.
    • Forgott to add a picture showing the correct height, just make it level with the hour wheel.
    • It is supposed to be completely flat, no wobble. If it's not flat there is a risk the disk is not just scew but the date ring also is misaligned to the star wheel. The snappy action during date shift will for sure not work in that case. A date jumper is supposed to do what the name applies, keep the dial in place with a small force, just to keep it in place only by friction will make the dial move a slight bit with every small chock the watch gets and I doubt even ROLEX haven't made it work that way, but one never knows ,
    • Welcome to the forum David, Glad to hear you survived the hurricane ok, Dont get any this side of the pond just windy and damp
    • Good morning/afternoon/evening/night, all. I've been an enthusiast for a very long time(I'm 65) but have never progressed past the stage of strip and clean. I'll set up my bench and then not touch it for a year or so, but I'm back. I live in Mexico Beach, FL and as most of the area our home was almost destroyed by hurricane Michael last Oct 10th, 2018, but lucky for my lovely wife and me the interior of our home was untouched, so watch bench, tools and my collection were all in great shape. Most of the home repairs are done with a few items remaining that are lower priority, so back to some sort of normal for us. I look forward to reading the forum for tips and knowledge. Regards...
