  • Similar Content
    • By HongJiho
      Hi my friends.
      I saw WRT video in youtube. It's so helpful to me. Thank you Watch Repair Channel.
      After watching video, I'm looking for watch repair oil and grease.
      I want know what oil & grease need to beginner.
      In addition, I want know what oil &grease used in video (7s26 repiar video).
      If anyone knew about that, help my work.
      I will very appreciate any information or links.
      Thank you to read my poor writing.
    • By Bethan36
      Hi Fellow People,
      Im reaching out as I’m currently learning all I can about watchmaking, and am working through the BHI distance learning technicians course, with my exam booked for May.
      I will need to service a quartz watch as part of my practical exam, and am learning about watch lubrication.
      A few months ago I found a great article that covered the technique for dipping and collecting the right amount of oil on the oiler, such as the speed and angle of the dip, however, I now can’t find it anywhere, no matter how much I search the internet
      Does anyone have or can point me in the right direction of instructions specifically on oil collection on the oiler?  As you will know there is lots on the actual oiling process but not the oil collection process.
      Any help would be greatly appreciated.
      Thanks
      Bethan
    • By east3rn
      Hello. I am considering buying a bottle of fixodrop and I found that there are many options regarding the quantity.
      Since I am hobbyist watchmaker, I don't service a watch very often.(Couple of them in a month)
      In this case, would it be okay to purchase the smallest amount of fixodrop(1ml)?
      One more thing. Is there anything else I should get to apply the fixodrop to my pallet fork?
    • By WorldPowerLabs
      Hello all,
      I'm about to service a Timex 260 electric movement.  It's running strong as-is, but I doubt that it has been cleaned or lubricated in its lifetime.  I do have the service manual for the movement and for most of the oil points, the SM calls for Moebius Synt-A-Lube, without specifying a product number (I intend to use Moebius 9010), but for the friction pinion the manual calls for "spreading type oil" (Woods AAAA oil).  I cannot find a cross-reference for this old Woods oil and most watch oils are, of course, specifically formulated to NOT spread...  so, I'm seeking advice and suggestions for a suitable oil to use on the friction pinion.  Also, if anyone thinks that 9010 is NOT appropriate to use for the various other points, please let me know.
      Thanks much!
      Ben
    • By Paul78
      Hi all, I'm thinking about investing in the set of automatic oilers available from cousins. They cost about 200 quid with the VAT, that's obviously a lot of money so just wondered if any of you use them and are they worth the money?
    • Welcome and enjoy the forum.
    • Hello guys. This is my last project – Seiko 6139-6010 aka Bruce Lee. Watch is from ‘69and it is based on the 6139A movement. Nice shot for the 50th Seiko anniversary of first automatic chronograph development. So please see the pictures below from all restoration proces. It took me 3-4 evenings. The watch came to me as non runner. Crystal was scratchy with many chips. Dial was dirty and dusty with signs of water damages. Hands lost their lume. Day calendar was loosen and didn’t work properly. Movement was complete but very dirty and dry – there weren’t any residues of old oil in the jewels. Somewhere were signs of water flood. I dissasembled movement and I gave it a bath in ultrasonic cleaner then i’ve assembled and oiled movement. Star disk od date wheel was repaird with small amouth of resin glue. Movement had tend to stop sometimes. Inspection showed that the tiny chip on the bottom pivot of the escape wheel. It was hard to see it. After replacment movement ran as a champ. I polished the hands cause there was rust and gave them new lume. Dial was cleaned. I didn’t touch the lume on the hours indexes. I was affraid to screw up it. I think now it is quite good despite the fact that the lume does not glow. Orginal crystal was polished but I decide that in the future I will replace it. Case and caseback got some polish works only with polishing paste, not too much cause I didn’t want to loose the sharpnes of orginal edges – as usual I did it. Bracelet was matted with abrasive wool. Everything was mix up and combined and there is the result. After measurments on timegrapher and adjustment it is a nice timekeeper. An amplitude satisfy me as well. Now I am enjoy to wear it. Please let me know what do you think of this restoration project and about my works on it. I appreciate your comment and your spend time. Cheers folks     VID_20191016_170551.mp4 VID_20191017_195141.mp4
    • Thank you for your introduction and welcome to this friendly forum.
    • Thanks for taking the time to respond. I especially like the see through back.  Wear it in good health.           Best wishes
    • Setting lever screw broke on my Timex 24 movement. I have another working 24 but in need to install the setting lever and new screw which seems somewhat impossible. Is there an easy way to get the lever and screw inserted into the hole?
