Lubricants
On 17/9/2014 at 3:46 PM, Mark said:
I use HP 1300 (instead of D5) on higher grade movements such as 2892 and the Dubois Depraz modules, as well as HP 500 in place of 9010 (except on balance end stones where I still use 9010).
Your list looks good.
I did a small list in this topic also. http://www.watchirepairtalk.com/topic/83-lubricants/#entry310
I took note of that list you shared, I will see which can I take to try my very first service, I´m making a list of materials and basic tools to perform thee task. Thank you all for your posts!
Hello all,
I'm about to service a Timex 260 electric movement.  It's running strong as-is, but I doubt that it has been cleaned or lubricated in its lifetime.  I do have the service manual for the movement and for most of the oil points, the SM calls for Moebius Synt-A-Lube, without specifying a product number (I intend to use Moebius 9010), but for the friction pinion the manual calls for "spreading type oil" (Woods AAAA oil).  I cannot find a cross-reference for this old Woods oil and most watch oils are, of course, specifically formulated to NOT spread...  so, I'm seeking advice and suggestions for a suitable oil to use on the friction pinion.  Also, if anyone thinks that 9010 is NOT appropriate to use for the various other points, please let me know.
Thanks much!
Ben
Thank you for your suggestion, rogart63.  You may be correct about the Epilame, but I'm not sure that's what they are referring to in this instance. The manual recommends stripping the movement only so far as removing the balance wheel and bridge -- then cleaning the remainder as a unit, and finally applying the oils -- so if a person follows this procedure, I can't see any reasonable way to get an even coating on the relevant part.
I have attached a screencap from the service manual, showing the location where they want the "spreading oil" applied (it's marked as "A").  The impression I get is that they are calling for an oil that will wick into gaps.
I can see how a grease might work here, though -- thank you for the suggestion.
They probably mean something else? Something that will spread around under there? Have no idea actually?
Maybe could dilute 9010 with Naptha so that it spreads more easy?
Thank you both for your replies.  I had a chance to begin stripping the movement apart and I found that I can actually gain good access to the friction pinion by disassembling the movement just a little beyond the officially-recommended degree of disassembly -- and by doing so, I'll be able to oil it directly with 9010 rather than hoping that the oil will spread to the proper area.
@Marc Funny, I was expecting 9010 for the pivots (instead of 1300), those devils are spinning! But I would be wrong (I checked the service sheet ;) The big speed is a relative one (between each two in each set). The entire reverser wheel speed is quite slow, so 1300 will do!
Thank you for that!
I am having trouble getting Lubeta into Australia as Cousins UK and Cas-Ker US wont send as it is dangerous goods. So I might have to make up my own Epilame of 9010 in Naptha if I can find the right ratio. Member Rogart63 suggested it might be 100 to 3 . 3 parts oil to 100 parts of naptha. Thoughts?
I understand you have to mix those two, but how do you actually do that in real life?
I believe you have to make a large quantity (with some sort of seringe). Because if I count 100 drops of naphta, they will be gone by the time  I finished counting :)
I have a relative who is a vet and who is practised in mixing small volume mixtures in mls. I am seeing him tomorrow (Aussie time) so I will ask unless it's resolved here in the meantime. I don't believe it's done in drops but in volume measure.
Edited by John Hondros
That stuff evaporates faster than an open bottle of scotch that's for sure. :) I am assuming naptha is the american for lighter fluid right?
  • 2 months later...
I'm pretty well set up for oils for wrist watches, but not so for pocket watches.
I'm yet to buy Moebius 9020 which I will be buying on my next order from Cousins.
I've just cleaned and serviced an 8 day car clock which I'm guessing is from the 20s or 30s which is essentially an oversized pocket watch.
Can I get away using 9010 on the pivots or should I wait until I get 9020?
Also I currently have 9415 for the pallets which I know is the recommended oil for watches over 19,800bph.
Should I also be investing in 941/2 for the slower beat watches, or will 9415 be ok too.
If you want to stick with Moebius use  clock oil 8031.
I always preferred JD Windles Clock Oil for all clocks apart from clocks that had a platform escapement, then it would be a watch oil but not too thin.
I have read that 9415 is especially developped for high speed escapement, and can cause loss of amplitude on slower beat watches. For that reason, after a long time using only 9415 on pallet stones I have recently invested in 941/2.
It is a lot thinner than 9415, but I can't say that I have noticed a difference in performance. I wanted to experiment with both on the same movement and measure the difference but haven't got arount to it yet....
As for the car clock, I have worked on a few and i used 9010 on the balance jewels, and D5/ HP1300 on the rest of the train with no issue, I could not justify yet another type of oil for this application, the clocks I was workin on were not exactly high end!
I had never heard of JD Windles Clock Oil before, so I looked it up.
The price is certainly good so I have added that to my list for my next order from Cousins as I'm not completely happy with the oil I have been using on clocks and 50ml should last me for ever.
This topic is now closed to further replies.
    • Hi guys, the question is what is a forum, a place for discussion and passing on information, idle chat and a bit of fun and I for one are the richer for it. When in Hospital last year with the Covid being force fed oxygen and feeling total sh1t and close to the pearly gates a daily look on the forum to see what was going down helped to keep me focused on the job in hand took my mind off the problem for a short while but it was a lifeline for sure. We chat to friends for that is what they become around the world read their posts help where we can post information where we can.  I like @Neverenoughwatches some times think of members past and wonder if they are still at the watches or given up, some drop in for advise and drop out again never to be heard of again. The forum reminds me of Yorkshire hospitality, The door is always open and the kettle on the stove. Long may it continue.   My two bobs worth.
    • Thanks all.   Movement is a Helvetia 800C. Don't know any history e.g. if the broken mainspring is original. Watch was bought recently as non-working. Really interesting piece that Jon, thanks. I'd only been thinking of length relating to power reserve. I don't have a mainspring winder (yet) so I'd like to avoid winding the spring into the barrel by hand. The old spring measures at 1.60 x .11 x ~290. Sorry, can't be exact on the length. The piece I still have is 275, but the second piece escaped during measurement. Best measurement I had for it was ~13. The micrometer does zero accurately so I'm pretty confident of the .11 Also, I'm getting the barrel ID at 9.5 on a vernier. I'm now wondering about going with a .11 spring? Given all of the above, maybe 1.60 x .11 x 300 x 9? Any thoughts? Cheers.
    • Funny that you should bring this up. I was thinking about it just the other day. What happens if something happens to @Mark? The social bit is fantastic and I would miss it dearly, but I worry even more about the content. Together we have created a gold mine of information which would be more or less irreplaceable if the site should disappear. People (often with a lot of knowledge) come and go. I sometimes wonder what happened to them and miss them. We have no idea unless we have some private contact information. When I was new here I saw a lot of posts by @Lawson. He had a true fire in his heart for horology and was asking for an apprenticeship in his signature. I found that very inspiring and often wondered what happened. Is the fire still burning? Did he get an apprenticeship?
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
