What's a good watch for a doctor
So my brother is preparing to take the STEP 1 (one his first major exams in Med School is my understanding). I would like to get him a watch as a gift; my first thought was an old pocket watch I could fix up, and I got to looking and apparently Elgin made a pocket watch with a "doctor's sweep second hand". They seem to be pretty rare/pricey, and a pocket watch may not even be that practical? (Granted, it's going to be more of a gesture, whether he actually uses it in his practice or not...) Then of course in terms of practicality, they probably want something they can easily clean and sanitize....
Any thoughts on a nice watch? Ideally something relatively "vintage", pocket or wrist
As a medical student myself I would agree with rogart63. I have been really wanting a wristwatch with the base 10 pulse grading. There are a bunch of different brands that make them, some much older and less showy as the seiko pictured. I fell in love with this base 30 medical wrist watch that I saw on Instagram a while back.
A pocket watch is an awesome gesture, but it wouldn't really be of much use. Our pockets are already stacked full of papers, pens, stethoscopes, books, and snacks. I would fear that anything too nice would get damaged pretty quick.
Wish your brother luck, and tell him that there is much greener pasture on the other side. 3rd year is much more enjoyable than the first 2 years of medical school, even if you have to take step 2 afterwards. And be understanding that the stress the month before that test is miserable. I studied roughly 15 hours a day, 6 days a week for a month.
My earlier post was sent in error, here's what I wanted to say!
As a gesture, anything will work and a pocket watch is nice. But as a working doctors watch, well it'll have a hard life, I would imagine these are the key requirements
1. Accuracy.
2. Have a chronograph. Pulsations is not really necessary.. most of the guys I know in the profession just take the pulse for 10 seconds and x 6... usually a wall clock is used!
3. Be able to take knocks
4. Waterproof, not only water but chemicals, bodily fluids.
5. As you've mentioned, easily cleaned and case should be of chemically stable materials, I foresee frequent washing with strong soap as a result of #4.
6. Cheap... I believe that in some procedures watches and jewelry are not allowed so watches will be taken off frequently, increasing the chances of getting lost.
7. Easily readable at glance.
Based on the above I would imagine something like a swatch chrono (steel) would be ideal, the strap can be changed out frequently as Swatch has them everywhere.
However if the recipient is a watchfreak, I would go with Rogart's suggestion. The 6139 chrono is cheap enough and can be made reasonably water-tight.
  HTH
Anil
Doctors watches are banned in hospitals in the UK for fear of them carrying germs. :thumbsd:
Have they banned neck ties yet? At least those have been shown in some studies to cause unnecessary germ exposure. I honestly don't know what I would do in the hospital for time if I didn't have my watch.
They should also ban the use of ties, outdoor shoes etc but they don't.
Also should integrate the door opening switch with the hand gel dispenser, that way the dirty sods that don't use it are forced to. Too many don't bother.
Sent from my Honor 5c
To what does base 10 and base 30 mean? I thought maybe it referred to the math being based on 10 but I can't see how that works for the base 30 watch shown above
Pretty much you count 10/30 beats of the heart and whatever the number on the pulse tach nearest the second hand is the pulse. So on the base 30 watch that I posted I would count 30 beats, and say the second hand was pointing at the 5 o'clock marker. That would make the pulse 72 bpm. Does that make sense?
More accurate definitely. But will also take long. Most cases now a days the patient will have a pulse-ox on that will read pulse and you would just read the screen so accuracy isn't really needed, primarily because he likely won't ever actually check and count a pulse.
The only time he would be checking a pulse manually, will be in emergent situations. In which case you likely need the fastest way to asses pulse which would be base 10. The only other time he will be checking pulses would be in extremities to just check for the presence of a pulse rather than the rate.
Good point! That makes me think, I could be a smart alec and give him one without a second hand. I don't think they include seconds in T.O.D. records do they...wouldn't really convey a vote of confidence tho
You must be thinking of  that fancy SOCIALIST healthcare.  Here in Callie-fornia the doctor still uses an inflatable cuff and a wall clock.  No kidding.  :D
You must be thinking of  that fancy SOCIALIST healthcare.  Here in Callie-fornia the doctor still uses an inflatable cuff and a wall clock.  No kidding.  [emoji3]
That's when you know your doctor is getting paid by the hour ha.
    • @JohnR725 that's very helpful.  I appreciate the time you took to give those instructions and post the pictures.  below is a picture of my staff, which looks identical to the ones you posted.  The approx measurements I got are: .772 on the left part of the staff; .715 on the right side of the hub; the hub is 1.107; and the overall length (minus the broken pivot) is 5.248; which seem to line up with the measurements you posted.  I didn't think to measure the pivot, which I'll do if there's enough of one left on the staff.  Thanks again.
    • Thank you to both of you!  I've been somewhat derailed by this quandary for a couple of days now. I am guessing that the point of the wider tweezers is to support the whole spring at the same time in an effort to prevent it going under tension... I have already discovered the Zen of a clutter free space, and trying to keep my work well away from the edge, however the most terrifying of the flights wasn't so short, I had my work in the middle of the table and nothing else around.  That particular launch was towards me.  I distinctly recall feeling the spring hit my left hand as it escaped.  I only found it by dumb luck, on the floor, between the legs of my chair.  I need to order a pack of replacements just in case.  I think I recall a thread discussing where to find them, and the differences between the clones and the authentic ETA ones, pointing out that they're not interchangeable (the clones being longer IIRC).  Now I just have to find that thread again.  What I haven't mastered is the zen of the search function here.  I'm sure I"ll get that down eventually. So this is similar to, but different from one of the posts I had found in my original searches (or maybe I'm just hallucinating, I can't find the post I thought I remember).  The bits about the corner filled in a gap in what I'd read before.  At least I have a more clear picture in my head about what needs to happen now.  Yes, I've learned about how touchy these springs are.  What I'm not sure I have a good grasp on is the understanding of what causes the spring to flex, other than to say "the slightest little touch"  I think I'm going to try a small bit of Rodico to position the spring next time.
    • I think it's stamped on the inside cover. 309 I think.
    • Hi all, needing a little help. I have an old Casio AQ-321G, but have no idea what battery it takes. I've looked around online, but cannot see anything... I see a 309 stamped on the case back, could this be it....? Can you please help, below are some pictures:
    • The radial teeth are for hte seconds register, and the other (which is simple and doesn' take away significant torque from the train) for the minutes register.
