Dial Feet Soldering Video
A work colleague asked me to have a look at his Ebel 1911 Discovery (ETA 7750). The hour counting hand was floating around in the case. Loupe inspection showed that the post was broken off in the hand - so before starting I ordered a replacement hour counting wheel. When I opened the case I found the dial was not attached - it was sliding around under the hands. Removal showed that both dial feet were broken off. Time to break out my dial foot soldering machine. Here's a video showing the technique. Enjoy!
  • Like 5
No marks left on front if done correctly. I probably ruined 5 practice dials experimenting with different solder, flux and technique. Note also that sometimes I use a staking set to support the dial. I use a flat punch that is just the correct size to hold the dial wire perfectly vertical. This is actually the technique I'd recommend. Key is to use the correct solder and to perfect your timing. If you flow the current too long you WILL burn the dial face!
Does anyone know if a car battery charger would be any good for this?
I have an old charger that can output 12v or 6v which I believe can cope with quite a high current. I was wondering if it would double as a dial foot soldering machine. Does it need to be A/C rather than D/C?
Also, what is the function of the carbon rod? Could you not just make contact with the wire or would that cause a problem?
Yes - I believe a car battery charger can work. Have a look at this: http://www.girr.org/girr/tips/tips1/solderer.pdf
You need the carbon rod which serves as the electrode. Carbon is an excellent electrical resistor. It is this resistance that generates the instantaneous, and localized heat required to solder. Without the carbon, you would likely overheat the entire dial and do irreparable damage :(. Carbon rods are cheap and easy to find online. You can file the end down to a pencil tip.
@sstakoff thanks for the info and the link, I will be giving this a try.
I actually salvaged a carbon rod from an old zinc carbon battery last night so my next step is to obtain some solder paste and conduct some trials.
I will report back.
  • Similar Content
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
