Looks like this watch will be my first vitim....
Don't think of it as victim, rather a patient that needs a doctor's touch. B)  I could see in the pic that your primary winding wheel screw has been used a bit more than normal. (often an indication it had been over torqued at some point in time) Probably wouldn't hurt to capture each step of disassembly with photos, in case you are called away from your "victim". Good luck and if you get stuck with something, just ask, someone should be able to help.
Molnija 3602? An improved SSSR variant of a 15 jewel Cortebert 616. Good choice, I think. Solid movements, affordable and still plentiful. Quite a few sites and videos about them too, Molnija is quite popular.
Another bonus is that one can imagine working on a vintage Rolex movement in a Panerai while rebuilding it, as mentioned Corteberts were used by them... :)
Good Luck ... I am new too... What I did my first time was take just a few components off and put it back together , then the next attempt go a little deeper and put it back. It was a good exercise and built a little confidence also gets you familiar with where things go.
Also as WileyDave suggested taking photos of each step is invaluable.
Using method I described above I was able to fix a broken watch ( it was just the mainspring) my first time out. Must have been beginners luck, because it seems the more I know the more problems I am starting to have. LOL
Regards
Anthony
I saw that screw you are talking about, it doesnt look to bad in the other photos.
13 hours ago, CapMoy said:
Hey Douglas1701
Good luck !...
I'm going to do the same to this elgin and see how it goes...I will try to do the same way adioro110 did on his .
Regards...
Good deal...hope it works out good...gonna be a little while before i get started. Still waiting on stuff to arrive. Im sure this one will look brand new when you get finished with it.
Doug
It is in not working condition seller said balance is not good but I will try to take all apart clean it and see how it goes ...I do not know , if possible , how to fix it .
I will take this as a practice before servicing my working Rockford watch...
Moises
6 hours ago, Endeavor said:
Perhaps this may be of any use? http://linuxfocus.org/~guido/molnija-pocket-watch/
I just serviced one, very nice and easy to work on; great "starter";
Thanks for the post. I actually found that site a few weeks back. The one i ordered was runing a bit fast, so i adjusted the speed very slightly and I put to test with a digital stop watch to see of it was keeping time pretty good...tested it for 30 minutes and it kept up second by second untill i stopped the test. I jave check it for two days now and it remains insync with my ipad....not to bad for $45.
thanks again,
doug
That's a good price !! I guess you have seen on that website that a nearly similar, or similar, movement was used by Rolex. Can't be that bad.
The one I just serviced was very nicely polished on the back (even with blued screws), but crudely finished underneath. Money had to be saved somewhere.
Chances are yours has a good finish all around. That you received a next to "freebee" is even better as a starter. Take your time, and the first watches will be under your belt ;)
Here is a pic of the one I ordered. There is a spot at the 10:00 o'clock position...looks like some hot gold solder or something similar dripped onto the plastic dial. Im going out on a limb here...and correct me if im wrong..but from what i have read about American railroad watch accuracy, this watch keeps better time. So far its at about 2 seconds per day which from what i understand is pretty dang good.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
