I have a watch that, whenever the hands come together at ie quater to the hour, half past the hour, midday etc they stick and the second hand continues.
How can I strighten them?  Have they been magnitised? or whatever caused them to do this?
It has me puzzeled as to why they are sticking together like this.
Thanks.
David.
Hi David, take the movement out of the case and make sure that the hands are parallel with the watch face and have clearance between one another. You can do this by gently prying the offending hand with a piece of peg wood or a matchstick. Ensure that you place a piece of polythene over the dial to protect it.
+1 for Geo's answer. I had this problem on a pocket watch. I held the hands down at the pivot point by gently pressing laterally with a pair of tweezers - to stop them potentially flying off - and then gently pulled the minute hand straighter with another pair of tweezers. Problem solved.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this type of crystal? Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
