Sizing replacement hands
skridlov
Among the large number of watches which we're trying to resuscitate (see my introduction post) the commonest minor fault is missing hands - usually blue steel. I've been wondering how to determine the shaft sizes required. Obviously if disassembled one could measure spindles with a micrometer but surely there's an easier way? Isn't there? Would identifying movements precisely allow this parameter to be looked up... somewhere? All informed opinions gratefully received.
Roy
10 minutes ago, skridlov said:
That looks to be the tool required - as a Bergeon product I suspect I will need a mortgage. But unless I'm mistaken it doesn't enable one to measure the spindles when trying to replace missing hands. Or am I missing something?
Roy
Keep your eye on this auction..
New listing Watchmakers pocket watch Hand sizer tools Nice tools for watch repairer
I'm hoping to win this auction - the sizing gauge (the WIT one) is completely unavailable it seems. Why would this be? I realise that a micrometer may sometimes be the only answer.
Also, how does one deal with very small hand retraction? The standard pullers are really quite thick and after fitting a dial guard they're far too big to fit underneath the hands?
I'm guessing that the answer is "carefully" but are there any tricks?
Roy
Even bidding 8 seconds before the end I failed to get these. (£66 + P&P!)
 The Bergeon style hand diameter gauge is easily available but a gauge to measure the pinions (term?) no longer seems to be made. These two were made by WIT who don't respond to emails. The main parts supplier in  UK (Cousins) can't obtain them. I'm baffled by this as trying to identify the movement and then source the appropriate data sheets is a lifetime's work given the number of missing hands I need to source. A micrometer is a very clumsy tool for this purpose.
Anyone know how to source one or an equivalent tool?
Roy
Edited by skridlov
Hi Marc
this comes up repeatedly. That tool is pretty easy to source. Here is an almost identical version of the WIT tool that I failed to get in the ebay auction, it's essentially similar to a wire sizing tool:
http://www.terapeak.com/worth/vintage-quick-fit-hr-min-watch-repair-hand-gauge-w-h-m-hands-834-1-pr-luminous/252282408776/
It's equally unavailable.
Now I'm an absolute novice but I'm baffled as to the scarcity of what looks to me like the simplest solution to a common problem (it's common to me, at least, as I have dozens of movements with missing hands). I'd  guess my Chinese digital vernier calipers aren't accurate enough to accurately measure the tiny dimensions required. I've ordered a micrometer but it's a huge and clumsy way to measure  what could be done with a simple perforated plastic gauge. These elusive gauges look, to my naive eye, quite indispensable - what am I misunderstanding?
Roy
Edited by skridlov
correction
Nope. Not a good pic but it has two series of holes down each side with sizes in lignes and mm alongside. The WIT version is almost identical and more recent. I can't see why anyone would need a special tool for measuring hands!
This whole issue has me completely hornswoggled.
Roy
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
