broken regulator pin
thessler
Hi
I'm in the part of the learning curve where just about every watch I touch ends up broken. So far this is not such an enjoyable hobby.
Upon stripping and cleaning and old Gerrard Perreaugx  I bent the regulator pin and of course when I tried to straighten it it snapped.
Instead of just creating another parts watch I thought I would give it a go, pretty sure it will end up in the scrap pile.
I found an assortment of hairspring  collet pins on e bay I'm hoping to adapt one, they have many tapperd  pins for clocks that would be my second choice but I have no way to turn them down.
If I'm able to get one of these to work any suggestions on how to hold it while peen the top over ? I see that as quite a challenge without bending the new pin.
As a side note, to clean the top balance jewel the hairspring needs to come off and un screw the regulator from the bottom. This is how I got in trouble. Do you guys go through all that work just for that one jewel cap routinely or just skip that one ?
Thanks for any advice Tom
Every time.
In many respects the balance jewels are the most critical in the whole movement as inconsistencies in the behaviour of the balance is what screws up the time keeping, and a less than perfectly clean and properly oiled pivot and cap jewel will introduce inconsistencies in the performance of the balance.
It is certainly a fiddly operation but it comes a lot easier with practice.
Fitting a new regulator pin without a staking set is difficult... but not impossible.
You can also buy a selection of pins to make the job of modifying to fit slightly easier. They are hard to find, but search Cousins for S37393.
You will need a small flat steel plate (such as a thick washer) with 2 holes in it - it must be thicker than the length of the regulator boot. One hole is for the regulator boot to go through and you will need a tiny one close to it for the new pin. Drill the hole for the new pin first then file the other hole until they are close enough together.
The objective is to support all of the area of the larger section of the pin so that you can tap the other end with a small hammer. No need to whack it! You don't want to distort the regulator lever and it requires very little to keep it in place.
Thanks guys
Stuart I actually have a staking set, really didn't think of that.
Not really sure how it would help can't picture the setup.  I am thinking put the pin in a stump with a tiny hole but I'm sure there would be no room to clear the boot. If you of someone else can expand on the staking set idea, I'm all ears.
Thank you, Tom
You may find that the roller punch (with the slot down the side) will suit.
If not then you may need to modify a hollow flat punch by grinding away one side to clear the boot. Choose the smallest hole that will fit the curb pin. You can buy individual replacement bergeon punches for 4.7mm sets quite cheaply.
