Seiko westminster chimer strange issue
clockboy
My wife purchased a really nice wall clock. It has a quartz Seiko Westminster/Whittington chime movement and all works perfect until 9.0 am. It chimes 9 chimes @ 9.0am then at @ 9.07am it chimes 9 chimes again. It then is out of sequence by 7 mins & as yet I don,t know if it sorts itself out. Just by chance has anyone come across this issue. I suspect the answer will be a new movement. :mellow:
Just an update it appears it only does this between 9.0am & 9.45am. then goes back in sync at 10.00.am.
My knowledge with quartz is limited but I am guessing there is some sort of timing disc for the chimes & just this area is corrupted/dirty. I will not touch unless the fault develops. I am normally in my workshop or out by 9.00am anyway . :D
https://www.cousinsuk.com/product/strike-chime-with-pendulum-seiko
I am the same not a great lover of quartz BUT her who must be obeyed purchased it.B)
For those who do own one or purchase one the set up is after fitting a new battery it only chimes the hours for the first 90mins & then it is in sync and chimes on the 1/4's & 1/2 hours. Also @ 11.00pm it stops chiming  & starts again @ 5.45am.
The only issue with this movement is between 9.00am & 9.45am which is fault I can live with.
Hello CB
"The only issue with this movement is between 9.00am & 9.45am which is fault I can live with."
You have noticed it, talked about it, thought about getting it fixed, I reckon it's going to "tee" you off and get into your head then it will have a big accident involving you and a hammer when the better half is out for the night (:-))
OH will probably chip in and say it's the best thing for it (;-))
Cheers,
Vic
20 minutes ago, Vich said:
Hello CB
Cheers,
Vic
:D
Is there much paranormal activity in your house, I have noticed that my screwdrivers and tweezers keep moving from where I left them when I am tinkering with my watches, sometimes they dissappear totally and re-appear underneath something else.  When I complain my wife just looks at me and shakes her head and mutters something about "getting worse".
Cheers,
Vic
  • 6 months later...
  • 4 years later...
  • 2 years later...
Ok so I have one of these and it works for a while then starts to chime at 24 past and adds an hour to the chime sequence. Sometimes chimes at 38 past also and becomes more and more erratic with respect to odd chiming times. If I reset the chimes (by pressing the AM/PM chime buttons, it chimes the correct number the first hour then goes haywire again... I did leave the battery out for a while and when I started it again it behaved perfectly for about a week then started misbehaving again. A friend in IT suggested removing the battery and leaving it in the fridge over night... haven't tried that yet  - just turned the chime down so I cant hear it!
Hi these are wholly quartz / solid state devices battery controlled with some plastic gear work. The gears can be removed and cleaned  but the whole movement costs around £ 30 as a replacement. Will take around an hour to fit and is the cost effective answer.    I built a clock for my Brother with the Seiko movement several years ago still up and running.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
