Building My New Watch Repair Workshop.
Mark
Amazing job Mark, real nice working place,...time to stuff the place with watches, tools and the works...no more tidiness!  :D
Cheers,
Bob
No bob, I plan to keep it tidy.....
... for about five minutes :)
So we've seen your workbench area Mark, what you doing with the remainder of the space in there?
Partially for my desk and computer. The other part is for more benches for my lathe, dirty work (soldering etc.) and equipment. And I have a small annex room for the polishing and ultrasonic machines and storage.
Mark makes a really good point here. I have a really small workshop & contamination after working on my lathe is a real problem. A complete separate section of the workshop is essential. I have to cover my work bench with a dust sheet before the lathe,drilling,filing etc. procedures as that **BLEEP** swarf gets everywhere.
Edited by clockboy
What a cracking job you have done Mark, working should be a pleasure. I would also thank you on behalf of the members for your kind words regarding their input to the forum. :)
Ditto. Well done Mark. As you mentioned in the video, if you want to find something out - look on the web.
Really enjoyed the tour of your workshop Mark, well done, looking great thus far!  Funny you should mention the radio being an important factor in your working day, I suffer from tinnitus, and have recently started to listen to the radio through my iMac which really does help work, and reduce me from hearing the ringing in my ears.
Fantastic video! It's really cool to see the inside of a working shop. I've been working up my nerve to approach a local watchmaker and beg for a tour. This is the next best thing.
All those tools...why isn't there a "drool" emoticon? And there's that Cousin's LED lamp again.
Thanks for posting!
Cracking workshop Mark. You have created a really functional work area. Have you ever calculated how much you have spent on your equipment. At a guess I would say you have at least 20k.
I have no idea to be honest. But I do know it never ends :)
Very true!
I have mild tinnitus, but it seems extremely loud at night sometimes, I found this app for my iPad which just plays for the amount of time you specify a particular sound you choose. It is a real big help and gets me to sleep most of the time.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
