Building My New Watch Repair Workshop.
Mark
Amazing job Mark, real nice working place,...time to stuff the place with watches, tools and the works...no more tidiness!  :D
Cheers,
Bob
No bob, I plan to keep it tidy.....
... for about five minutes :)
So we've seen your workbench area Mark, what you doing with the remainder of the space in there?
Partially for my desk and computer. The other part is for more benches for my lathe, dirty work (soldering etc.) and equipment. And I have a small annex room for the polishing and ultrasonic machines and storage.
Mark makes a really good point here. I have a really small workshop & contamination after working on my lathe is a real problem. A complete separate section of the workshop is essential. I have to cover my work bench with a dust sheet before the lathe,drilling,filing etc. procedures as that **BLEEP** swarf gets everywhere.
Edited by clockboy
What a cracking job you have done Mark, working should be a pleasure. I would also thank you on behalf of the members for your kind words regarding their input to the forum. :)
Ditto. Well done Mark. As you mentioned in the video, if you want to find something out - look on the web.
Really enjoyed the tour of your workshop Mark, well done, looking great thus far!  Funny you should mention the radio being an important factor in your working day, I suffer from tinnitus, and have recently started to listen to the radio through my iMac which really does help work, and reduce me from hearing the ringing in my ears.
Fantastic video! It's really cool to see the inside of a working shop. I've been working up my nerve to approach a local watchmaker and beg for a tour. This is the next best thing.
All those tools...why isn't there a "drool" emoticon? And there's that Cousin's LED lamp again.
Thanks for posting!
Cracking workshop Mark. You have created a really functional work area. Have you ever calculated how much you have spent on your equipment. At a guess I would say you have at least 20k.
I have no idea to be honest. But I do know it never ends :)
Very true!
I have mild tinnitus, but it seems extremely loud at night sometimes, I found this app for my iPad which just plays for the amount of time you specify a particular sound you choose. It is a real big help and gets me to sleep most of the time.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
