New case for AS1674
ebay purchase movement, which is OK, except the second hand post was missing. Probably why sold as spares or repair. Also have found one of the dial screws is missing
Fortunately tracked the movement down on www.ranftt.de and then on www.oldswisswatches.com, and tracked the movement down as an AS1674 and luckily found the part on ebay (the part cost more than the movement!!)
Case will be 3 pieces: case back with movement holder, case body with lugs, and bezel. Raw materials;
Case back with movement holder in brass. 2 pieces of 3mm brass sheet to get the thickness
Case body will be steel tube, with brass lugs silver soldered on. Plan  to blue the case body to see how it looks against the brass. Bezel will be polished mild steel
The picture just shows the second hand post in in place and movement seems to be working fine (not cleaned)
Left to do is bezel, dial, dial markings, hands, glass and crown - fingers crossed!!
  • Like 5
You have the patience of a saint and the hands of a master craftsman.
I'm not easily impressed, but this is so far over the top, that bluing just "pops" off the brass, solid movement as well.
You should (and will) be proud of your work and skills, Top Drawer!
Dave
Hi Watchtime, yes it is heating polished steel. It is not permanent so not really suitable for a watch case, but this is playing. Towards the end of the project I will spray with laquer to see how that improves the durability, and also it will help seal the brass
  • 4 weeks later...
A bit more progress. Should be able to get a few more hours this weekend to get the hands finished
4.jpg.12ad89ef476997504136db5c63157214.jpg5.jpg.7bdebe9057f9ea8c62406da79ab6659a.jpg6.5.jpg.259e4a2ed5b9c1a751f1bdfdf5478ceb.jpg6.jpg.d38a6caa7f8e98edf9a3c0b11235d2eb.jpg8.jpg.ca48e3b39c88336225d595bfe92daaa8.jpg10.jpg.58c417152d7df692a938f07ddf64ecad.jpg11.thumb.jpg.09ef39b1cf586bc7a7e10235b0d9386b.jpg12.jpg.6d5ded08369709c9ffc752cfcd39ef04.jpg13.jpg.7c9f9b0dc6742e4c2f3e721cffa816a5.jpg14.jpg.0da13de9b54ad798e58067c6dd7e1a14.jpg15.jpg.7b53a6b3db5bdaece39ce74ad58b8a0f.jpg8886.jpg.c2f55ddaf5bf630a6e6ffaf5cb32b473.jpg8887.jpg.4da33b160b49c031443e298070648c25.jpg8888.jpg.0c64fe9bcc7e5f53b4d12d771c1dafc8.jpg9911.jpg.ec8e24a83608cd282278202c0408dfaa.jpg111111.thumb.jpg.627f242cd525da2be01460c4fda64ddc.jpg
Edited by Michael
pictures all loaded twice
This project has got to the stage where I am getting glad it is over. Anyway, crown made, parts sprayed with clear laquer, acrylic fitted and strap fitted. A few other problems I had to deal with to get the watch keeping regular time. The watch now keeps good time and I will regularly wear it and see what snags come up (which I am sure they will !!)
58b206963b926_IMG_4020small.jpg.f744403d830fd2035b0988bb7a4aaba7.jpg58b2069b9905a_IMG_4018small.jpg.d0fad549491cfe23090a85c74ddc2ef1.jpgIMG_4031small.jpg.d0dd210d8424722acd8e23d8536750ac.jpg58b206a1bf156_IMG_4016small.jpg.0f37936852587460cba28e7468c1d1de.jpg
  • Like 7
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
