Rolex Real or Fake
Man if that was an Omega Constellation I would chime right in...:)
The bezel colour and finish look to be very poor quality...almost garish for a Rolex. But then I have only ever seen pictures of a Rolex and never had one in hand... also on the underside of the top link of the bracelet the finish looks very rough and course. Need a better front shot to asses the dial better...Also  the finish on the bracelet is again very course, although the bracelet could have been changed. It almost looks like the lume pip for the bezel is not centered on the triangle?? perhaps the angle of the shot...or not...
Something about that bezel...is the center tine of the Rolex crown in line with the 12 marker triangle?
I say fake, but only going by a poor picture and no experience and the fact that there are more fake Omega's and Rolex's than there are the real thing.
Of course opening her up will tell the tale :)
Ron
Hmm lets see, well there's just nothing  right  about it what so ever, it's a complete turd. Bezel from a GMT incorrect, date window magnification way off, hour markers wrong, dial wrong, I think your having a laugh :D
I think I do have the answer. The strap is a Walmart special :) The Rolex strap is missing a connecting link ( to be purchased). This watch was picked up in Egypt by a pilot friend of mine. The average Joe would do not know it is a fake. It actually has the weight and feel of an original.18b953786973214334969e1b1233bec6.jpg
In an effort to combat fakes, more than a few years back Rolex started putting engraved "Rolex" inside the dial, around the rim above the dial, one quick way to tell... even then the fakers quickly came up with that same look. Dials, hands, crystals and even weight are a quick way to tell, if it doesn't look or feel right, probably isn't, also Rolex has their own brand/blend of stainless steel,(not like 316L) I read somewhere, that won't discolor when polished, usually the stem will break on copies if unscrewed or the date wheel will break, not worth much effort for parts, IMHO.
Agreed, there are better fakes, Complete turd!:biggrin:
I'm glad I did not buy it :). It was a gift for fixing his other fake.3a9e964fdf6814dab0ae6674baedaaa6.jpg
I personally have not got any problems with fakes/copies providing they are sold as such. It's when they are sold as genuine that is the real issue for me. As far as repairing I avoid and refuse to touch them. What worries me is after the repair and it is then sold as genuine am I then party to the fraud ?
My main concern with a service of this watch is that, if I pooch a part i would not know how to get a replacement as I really can't identify the movement.
Sent from my GT-N5110 using Tapatalk
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
