Question
I've just changed my cleaning fluid in my Elma cleaner to the Elma WF Pro, I've done one movement, the fluid was clear but now it's gone blue. Does anyone know of this is normal? Or should I change it?
Share this post
Link to post
2 answers to this question
  • 0
How long did you leave it in the cleaning fluid? I was just now looking at their PDF not seeing what I was expecting to see. I've experienced with ammonia-based cleaners if you leave it too long it will remove the copper from the brass the solution turns blue the brass gets a kind of frosty look to it. But this is usually when you go way past the acceptable cleaning time.
http://www.elma-ultrasonic.com/fileadmin/downloads/CleaningAgents/ProductInformation/GB/P_wf pro_GB.pdf
Share this post
Link to post
Answer this question...
Loading...
  • Similar Content
    • By MrRoundel
      Greetings folks. I've been working on watches as a hobby for about 20 years now.  I started out on pocket watches and have never cleaned a clock. In fact, I had a great cleaning machine, with the big jars, and a few other clock tools, that I gave away to an aspiring clock guy over at the Tascione site. But I digress...
      Nearly 20 years ago I bought a Hamilton model 21 ship's chronometer. It's an early one, pre 400 serial number, and is a thing of beauty, as these generally are. Back when I got it, I had a professional service it for me. It was done well, but wasn't cheap. $400-500, IIRC. I used to display it in my living room and run it occasionally just to hear the escapement and marvel it its accuracy. From about 2009 to 2014 it sat in my storage unit, waiting for new digs. In 2014 I wound it up and it took off running. I let it run down and then put it away for a couple of years. When I pulled it out, I discovered that it had a broken balance pivot. While originally I thought someone had knocked it over and wasn't copping to it, but now, after inspecting the upper pivot's wear, I don't think that's the case.
      After botching the first staff I got trying to replace the hub, I set it aside again for the past couple of years. The way I broke the staff was I overestimated how deep the hollowness went in my hollow punch that I was using to tap it on. It bottomed out in the punch and destroyed the pivot.
      Now that I'm finally over that disappointment, I decided to give it another go. I bought a staff that already had the hub installed. I may have to polish the lower pivot, as it doesn't seem to want to set in the hole jewel properly. I'm in the process of verifying all of this. I had to tear down the chronometer at least to the point where I could check to see if the broken part of the pivot was impeding the staff from setting properly. The hole jewel is clear.
      I'm doing the best I can to do it right, and get it running again. I won't be running it, but want it running just in case I should decide to sell it. Otherwise the value drops quite a bit. Since I have it completely torn down now, I might as well clean and oil it. Does anyone have a hot tip on the best cleaning solutions for cleaning these chronometers? I'd like to use something that will cross over and work for my cleaning of watches as well. I have both an ultrasonic and the small L&R mechanical. I have one more fresh batch of cleaner and rinse, petroleum, no-water, formula. Should I use that, or make, or get, something new? Any tips for oil and grease types to get me by? Any suggestions are appreciated.
      I do have the Manual for the movement.
      I know that this is risky business, my working on this chrono, but I just can't afford to spend another $500 to get it running. Plus, I heard that if you're going to run these, you've got to spend this $500 or so to service them every few years. That is not going to happen. Feedback, suggestions, warnings, tips, etc., are all welcome. Many thanks. Cheers.
    • By martintheone
      My great Aunt died a couple years back. She had had been married to a man that owned a jewelry store back in the early 80's. In her estate was a number of great treasures and even literal gems.  After the estate sale not much was left, but I did end up with what Ive deduced to be a Vintage Elma watch parts cleaner.  And that is about as much as I have been able to figure out. None of the searches I've performed on the internet have returned with the exact model that I have. Not even an image... Similar , yes. The same . no. ..
      I don't have a clue as to how to operate any watch parts cleaner, much less one with minimal text (german) to clue one in on function of switches and dials. So, I can't verify it is in working order. I did notice that the plug had a short in it so I replaced that, Plugged it in and a light above the switch lights up after being flipped, but again end of my road of investigation... So basically, I would really appreciate any information at all about this machine
    • By jakobvinkas
      Hello, I could not fint any answer to this on any other thread.
      Im using Isopropyl alcohol for the last step of hand cleaning movements. However i can not find a good way to throw used liquid away. How do you do it, I know that the liquid will turn into gas eventually however since i fill a small jar there is always going to come times when i need to throw it away. Where do i throw it?
      How do you do it?
      Thanks in advance, Jakob
    • By dreja
      Hello,
      I have disassembled the Poljot 2209 movement.
      I would would need your advice, if it is ok to wash also the "double gear" and how to oil it later...
      Thanks
      Andrej
    • By bertmengels
      Hi to you all,
      I was wondering, if you use a regular ultrasonic instead of a watch cleaning machine. How would you rinse your parts? And how many times? In which solutions?
      I always cleaned my parts in the ultra sonic with a solution and rinsed the parts in benzine( that's the way an old watchmaker learned me) but i've found out that very often this does not give me the results i was hoping for. Can I perhaps get little jars with a rinse solution and run those in the ultra sonic?
      thanks!
    • So, I'm gonna try and post a couple of photos shortly, both Seiko of course for reasons stated earlier.   The blue one is apparently called the "ashtray" bezel. It winds, works, keeps good time, over the last 8 hours anyway, the only snag being the day pusher function does not operate every time.  The silver one is a Seiko deluxe which does not wind or work, in fact it makes a disheartening rattly noise when shaken, like something has come adrift inside.  They were purchased as items for me to take apart and study, then hopefully reassemble, having cleaned and lubed.  The ashtray arrived from India today, the deluxe arrived from Japan today, both were ordered last midweek. How easy these days to begin a new hobby, what with international freight, the Internet, and training vids on you tube. I may not even renew my porn subscription, this hobby could save me money!!!   Next purchase will be a set of intro level tools, then to business.
    • One option for white is to use a toner reactive foil. This is what I used with success: https://www.circuitspecialists.com/pcb-trf-white.html I didn't use decal paper for printing but used toner transfer paper. My presumption this would still work with the film-less decal paper. Getting the toner reactive foil to work is tricky though. It requires both heat and pressure. Too much heat and pressure and entire dial turns white. Too little and it would only partially stick. It also requires some brushing to remove any bits of foil left over. It took a lot of time, practice an patience for it to work for me but it is certainly possible. I wouldn't recommend this on a dial you only have one-shot with, try with a blank you can practice with.
    • Ah yes, a coupla good ideas there!  I'll go find a welder and cadge a rod, that's a cheap option. Thank you fellas.
    • Thanks, nickelsilver!  You mean, the first hairspring, the one still mounted is beyond repair? I haven’t touched it. If it is what you meant, it’s disappointing.  Thanks for the clarification on the vintage tools!
    • Can we have a look at the back. I'm sure the movement comes out from the back. That is not a waterproof case.
