Question
I've just changed my cleaning fluid in my Elma cleaner to the Elma WF Pro, I've done one movement, the fluid was clear but now it's gone blue. Does anyone know of this is normal? Or should I change it?
Share this post
Link to post
0 answers to this question
There have been no answers to this question yet
Answer this question...
Loading...
  • Similar Content
    • By Jehan
      Hello everyone!
      Looking for some advice on what kind of grease you would use for the maintenance of the machine itself.
      I want to ensure the proper workings of the machine. I’d love to be able to take this thing completely apart but not sure where to even start.
      Has anyone here ever serviced one of these before?
      Any advice would be highly appreciated!
    • By MrRoundel
      Greetings folks. I've been working on watches as a hobby for about 20 years now.  I started out on pocket watches and have never cleaned a clock. In fact, I had a great cleaning machine, with the big jars, and a few other clock tools, that I gave away to an aspiring clock guy over at the Tascione site. But I digress...
      Nearly 20 years ago I bought a Hamilton model 21 ship's chronometer. It's an early one, pre 400 serial number, and is a thing of beauty, as these generally are. Back when I got it, I had a professional service it for me. It was done well, but wasn't cheap. $400-500, IIRC. I used to display it in my living room and run it occasionally just to hear the escapement and marvel it its accuracy. From about 2009 to 2014 it sat in my storage unit, waiting for new digs. In 2014 I wound it up and it took off running. I let it run down and then put it away for a couple of years. When I pulled it out, I discovered that it had a broken balance pivot. While originally I thought someone had knocked it over and wasn't copping to it, but now, after inspecting the upper pivot's wear, I don't think that's the case.
      After botching the first staff I got trying to replace the hub, I set it aside again for the past couple of years. The way I broke the staff was I overestimated how deep the hollowness went in my hollow punch that I was using to tap it on. It bottomed out in the punch and destroyed the pivot.
      Now that I'm finally over that disappointment, I decided to give it another go. I bought a staff that already had the hub installed. I may have to polish the lower pivot, as it doesn't seem to want to set in the hole jewel properly. I'm in the process of verifying all of this. I had to tear down the chronometer at least to the point where I could check to see if the broken part of the pivot was impeding the staff from setting properly. The hole jewel is clear.
      I'm doing the best I can to do it right, and get it running again. I won't be running it, but want it running just in case I should decide to sell it. Otherwise the value drops quite a bit. Since I have it completely torn down now, I might as well clean and oil it. Does anyone have a hot tip on the best cleaning solutions for cleaning these chronometers? I'd like to use something that will cross over and work for my cleaning of watches as well. I have both an ultrasonic and the small L&R mechanical. I have one more fresh batch of cleaner and rinse, petroleum, no-water, formula. Should I use that, or make, or get, something new? Any tips for oil and grease types to get me by? Any suggestions are appreciated.
      I do have the Manual for the movement.
      I know that this is risky business, my working on this chrono, but I just can't afford to spend another $500 to get it running. Plus, I heard that if you're going to run these, you've got to spend this $500 or so to service them every few years. That is not going to happen. Feedback, suggestions, warnings, tips, etc., are all welcome. Many thanks. Cheers.
    • By martintheone
      My great Aunt died a couple years back. She had had been married to a man that owned a jewelry store back in the early 80's. In her estate was a number of great treasures and even literal gems.  After the estate sale not much was left, but I did end up with what Ive deduced to be a Vintage Elma watch parts cleaner.  And that is about as much as I have been able to figure out. None of the searches I've performed on the internet have returned with the exact model that I have. Not even an image... Similar , yes. The same . no. ..
      I don't have a clue as to how to operate any watch parts cleaner, much less one with minimal text (german) to clue one in on function of switches and dials. So, I can't verify it is in working order. I did notice that the plug had a short in it so I replaced that, Plugged it in and a light above the switch lights up after being flipped, but again end of my road of investigation... So basically, I would really appreciate any information at all about this machine
    • By jakobvinkas
      Hello, I could not fint any answer to this on any other thread.
      Im using Isopropyl alcohol for the last step of hand cleaning movements. However i can not find a good way to throw used liquid away. How do you do it, I know that the liquid will turn into gas eventually however since i fill a small jar there is always going to come times when i need to throw it away. Where do i throw it?
      How do you do it?
      Thanks in advance, Jakob
    • By dreja
      Hello,
      I have disassembled the Poljot 2209 movement.
      I would would need your advice, if it is ok to wash also the "double gear" and how to oil it later...
      Thanks
      Andrej
    • Hi everyone, I'm a newbie from Turkey, watch enthusiast I hate automatic watches, I believe it's 99% a useless gimmick, an unneccessary complication, I think it only makes sense with screw down crowns, I'd rather have a slimmer/simpler watch and enjoy winding it directly - recently re-sparked my interest in watches by buying a Tisell Miyota Pilot, first think I did was to remove the winding weight - converted the watch from a noisy/flimsy thing to a rigid/joy to wear device Recently started buying defunctional vintage watches to learn basic servicing to be able to maintain my watches Originally I was going to practice on simpler hand winding movement, like the Omega 620, which is cheap and easy to find, but because of this coronovirus stuff, couldn't yet import them Today I received and opened up an Omega 552, from a 166.022 - I love the case, so I decided to endure the auto movement Anyway, the crystal was cracked, maybe pre-broken, as I used a metal latch tool. I cracked the crystal, not the front part, but just part of the edge, should've read this forum first and applied the syringe air pushing method, since I believe it was pre-broken, I'll attempt to glue it and use the crystal anyway - maybe the previous opener of the watch just re-inserted the crystal that way Onto the good stuff, my approach to watch servicing will be disassembly, ultrasonic cleaning, re-assembly with minimal lubrication - so I started by removing the winding mechanism, and the tiniest of screws fell onto my hand - and with the auto winding mechanism removed, and this small screw outside the movement, the movement started working again! (The damage to the dial was pre-done, I'm a newbie hobbyist, whoever tried to yank that dial out of the movement/case, was probably sub-human :) My question(s):  1) Is this small screw from this movement / could it be the reason the movement wasn't running, maybe it was yanked in somewhere? 2) Do you guys think I can / should just re-assemble the watch without the auto winding mechanism? I don't enjoy it, and since the watch started ticking without it, I thought I could just re-assemble it and give it a go, without risking things with my amateur involvement (this is the cleanest vintage watch movement I've ever seen, no dust/buildup inside etc.) Worst case scenario, I was going to buy a replacement movement, but hopefully not needed
    • Hi You definitley have an issue with the barrel/arbour, If you can remove the cap from the mainspring barrel and check on the condition of the spring its self it may be a contributary factor.
    • I usually end up trying every tool I think may work.
    • Thanks everyone for the great responses.  Hope I get enough time to practice being just hobbiest currently! Just my mobile platform. Chrome browser, Android O/S.
    • Thank you watchweasol. It took me a while to figure out how to the jam the train wheels and while I was trying to figure that out, I discovered the horn on which the pallet fork moves back and forth was bent and that did not allow the escape wheel to move further from the entry stone of the pallet fork. I managed to straighten that and tried putting on the balance but no luck. Then, I used a thin needle to try and jam the train of wheels and the end of that neddle was resting on the center wheel. In that state, when I tried to move the pallet fork, it was responsive and I could see it was allowing the escape wheel to move with corresponding movement of the other wheels. The moment I removed the needle from the 'jar' position, the escape wheel was no longer responsive. I'm still trying figure out what the issue is considering all wheels were spinning freely after I removed the pallet fork and tried winding the barrel.  Secondly, I did everything as you said i.e. Only put the barrel, ratchet and the barrel gear. After winding the spring a little, I tried to release the click spring but the barrel did not unwind. This is what I'm examining currently as I write this.  P. S. I manually unwound the power from the barrel by rotating the ratchet gear in the opposite direction till the point I could not rotate it anymore.
