Enlarging watch hands holes
number98
Hey guys, I have just bought a pair of hands for my watch from ebay. I knew from the beginning that the gmt won't fit on the movement without some modifications. I did some research on enlarging watch and found out that one needs a broach and a watch hand tool. I was wondering if its possible to secure the hands using the watch hands tool and use a diamond file? Because I searched cousins and my local watch material supplies shop and they do not have the broach that I want which is 1.50mm. Thank you very much.
1 hour ago, clockboy said:
Your research is correct. I use a cheap version ( aprox. £7) of the Bergeon style tool & it works fine. A fine broach & remove gently as it is really easy to go to far see pic below:
Thanks for the reply. Unfortunately I don't know where to source the 1.5mm broach as most of the broaching sets comes with a 1.6mm. Also, the broach for enlarging the holes is consider a cutting or a smoothing broach? Thanks!
46 minutes ago, clockboy said:
There are plenty of suppliers of broaches. Cousins is good also for quality Eternal tools is a good source.
I would use a smoothing broach to remove slowly.
https://www.cousinsuk.com/product/0060-to-200mm-german1
https://www.eternaltools.com/watchmakers-smoothing-broaches-set
Hi thank you for the reply. Unfortunately the link that you had attached doesn't include the 1.50mm. :( Because the hands I bought from ebay( I haven't received them), I think the hour hand will fit but the gmt won't. Because on my movement according to ofrei is 1.52mm but the hands I bought is 1.40mm hence the need to enlarge it. Also I would like to ask is the Bergeon 30464 measuring gauge mandatory for this kind of work? Is it ok to work without it as it is quite expensive. Thank you for helping me!
I could be wrong here but if I am then I'm sure that someone will steer me back on the right path.
As far as I know broaches are not parallel sided like reamers, they are very slightly tapered (all of mine certainly are), so you use a broach which will fit the hole to start with and push it progressively further in until you achieve the desired size, measuring as you go so you know when to stop. The taper is so slight that over the fraction of a mm thickness of the hand tube it is negligible.
As CB says, use a smoothing broach. A cutting broach will remove material, potentially weakening the hand, whereas a smoothing broach sort of pushes the material out of the way without removing it.
You're correct Marc, the readers are tapered.  I suspect the 1.6 will be the thick end of the reamer, so this size will probably be the correct one.
As an example, my 2mm reamer is 1.5 at the small end.
    • Unfortunately I'm not that lucky. I started on the train side and after I noticed the binding I pulled everything out except the driving wheel to rule everything else out. It still binds. I'm going to double check that the pinion is fully seated on the staff first, then if no joy I'll push the bridge jewel up a fraction of a mm. Fingers crossed!
    • Happy to have helped, great way to start the day with a win! 🥳
    • Thank you for the advise!! It worked. The setting screw was a lock/unlock to remove the rotor.
    • I have that French tech sheet too, it is a little different than the English one (eg, it doesn't have the auto works diagram). BTW, it looks like you are looking up the case number in the 1979 ABC supplement. The 1974 ABC catalog does have the 3093 case. As you determined it takes the 1222-5 crystal.  When I serviced my President 'A' (which also takes that crystal), I was able to fit a 29.8 crystal from my DPA crystal assortment. Those are, in my opinion, a great deal. The assortment comes with 10 sizes each from 27.8mm to 32.4mm in 0.2 increments. I pretty much use them for any non-armored crystal that takes a high dome crystal. I think they no longer make them but Cousins has still has some in stock but when I bought them they were around $40 for the set and now they are around $100. Still, at 40 cents a crystal it's still a good deal. For the large driving wheel, I remember I once assembled the keyless/motion works first and when I placed the large driving wheel it was interfering with the setting wheel on the dial side as the teeth were not fully meshing and it wouldn't fully seat. If that isn't the issue I got nothing and am looking forward to see how you solve it 🙂
    • Not sure, but just looking at it, it seems like the screw on the right may be a fake? The one on the left may not be a screw in the regular sense at all, rather a 2 position device, I think you need to point the slot towards either of the 2 dots and one will secure and one will open. Like I said this is just my best guess looking at the pictures.
