Lwo283 service
AP1875
Hi guys, I found a LWO283 on eBay for a very good price, so I thought I'd pick it up and try and service it.
For those that don't know this movement is an ETA 2892 with a Dubois Depraz chrono module.
I've serviced a 2892 before so interested in having a go at the module.
Anyway, slight problem I'm not sure how you remove it from the case. At 6 and 12 I have turned the two tabs so it's no longer latched in. Taken the stem out. And it's not moving, I don't want to try random screws and remove it. I need to be confident on how it actually comes out.
Any ideas?
I'm sure it does come out the front.  The two "tabs" that you mention look like rotary knives that cut into the dial pins to hold the dial in place.
I think you will have to remove the front bezel (if possible) the or the crystal, the screws that hold the movement into the case. From what I see it looks like there are three of these screws.  Once the above has been accomplished, the movement should come out the front of the case.
Can it be done without these. The case/crystal is going in the bin
The bin is something unknown to watchmakers [emoji4]
I suggest that you try to do things the proper way without using force or breaking things. It is part of a quality approach to this hobby.
That'd be the tool - assuming you have a domed acrylic crystal with enough to get a hold of the egde.
The tool is also good for fitting new crystals... but I had to deburr the claws on mine to prevent marking the crystal when I first got it. I suspect if you buy the bergeon version then this would not be required!
You might get away with blowing the old crystal out - not so easy with a chrono case, but it is accepted practice to use a small pump on the pendant tube. There is again an expensive solution to this problem (below) or you could improvise with a bicycle pump, ballon pump, syringe, etc.
https://www.cousinsuk.com/product/glass-removing-pump-bergeon-5011
Hi Stuart, thank you for your detailed reply.
I've just checked to specs for the watch (Philip sea lion) and it has a sapphire crystal. Would that require a different type of puller?
If you have a case back press fined a dye approximately the same size of the Crystal not the bezel. If you don't have a case back press, improvisation is required, possibly a plastic bottle top ? Hold the bezel firmly in your fingers, face down. Place dye over the inside of the Crystal. A short sharp positive hit to the dye with a suitable hammer will release the crystal from the bezel.
Sent from my SM-T585 using Tapatalk
If I have understood your explanation correctly I don't think I can do this because the movement is still in the watch, so I can't place a dye on the inside of the crystal.
Ooops I thought the bezel and crystal was off the case but you will need a decent case back and crystal press to fit the new crystal. So you have removed the bezel and the movement is still in place with the crystal over the dial ?
Have you tried pushing the movement from behind out the front
If the crystal is attached to the case, not the bezel, then this definitely comes out the back.
If the movement will not rotate in the case, it is likely you haven't freed it yet. There are 3 other large screws around the edge of the movement, are these the retaining screws?
Stuart, I think I've reached a point where I'm just going to have to remove them and find out. I was kind of reluctant to do this without knowing for sure. I thought the two tabs at 6 and 12 were for holding the movement in place, I've not seen an ETA movement where they use a screw as well, however I have very limited exposure as I'm just starting out. I will remove them and report back.
If life only was that easy. A high number of watch producers buy in movements and fit to cases in a variety of ways. If after removing the screws it still doesn't want to move. It still could push out to the rear, including the crystal, or the front, note the size of the dial diameter and what way it's likely to come out. It could still be the screws holding the movement in but after removing, dirt is holding the movement in. There could be a movement ring holding it in position or the movement may need to be rotated first prior to removal.
Best of luck anyway
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
