Omega 420
Jim
Hi its been a while since I have posted   I have run into an interesting problem while servicing an Omega 420 movement     I will attach a photo   I fully serviced the movement  very clean now the photo was a before shot.   No broken pivots no cracked jewels.  But when I leave the screw that I have the blue arrow pointing to loose the watch runs  if I tighten the screw it stops.  No other screws seem to make any difference.  I have checked end-shake on all the gears.  while the screw is loose the watch will run all the way down.  I did notice that in stem down position the watch runs -100 spd  slow  dial up or dial down its fine  and long as the screw is not tightened?     All suggestions welcome.
Sincerely
Jim
Have you checked to see if the plate has been bent. Make sure the jewels both ends are clean, the same with the pivots. When you have the plate screwed down do you still have good end shake? Is it the right screw. Is the jewels seated correctly.
yes I have checked end shake and the jewels   with the screw tightened   every thing is very clean  the plate doesn't  appear to be bent  Its the large plate if it was machined improperly the watch would have never worked.    I am thinking one of the pivot ends may be slightly deformed I only looked at them under a loop    guess I need to look at each one under my microscope.
Thank you for your thoughts
Sincerely,
Jim
Take it apart and put only one wheel in at a time to see if you find a tight one.  Doing this with only one wheel will hopefully find the bad one.  Do this procedure with each wheel in the train, and rember to tighten the plates fully before testing how well each wheel spins.
If you don't find a single tight wheel, keep adding one extra wheel, tightening the plates every time intill yo have them all fitted, at some point along the the line you will probably find the offending combination that causes it to go tight.
Great advise Geo    I think the tight one is the double wheel that connects the train to the second hand.  I will try that one first alone.   I am thinking one might be slightly bent  because each wheel by itself seems loose even when I tighten the screw.   But the train wont spin freely even with the pallet fork removed once the screw is tightened fully  1/2 turn and it spins fine      I think that is why the watch was put away so many years ago.    The double wheel is a pain to get in place  lol
Thank you sincerely ,
Jim
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
