Greeting from Queensland Australia
Sebastian
Hi all,
There seems to be a lot of Australians signing up recently and I'm pleased to be among them. I'm fairly new to the watch maintenance game, but I'm slowly building a tool and information set from these here interwebs.
It's worth noting that the Australian government has all but eliminated apprenticeships/trade schools for watchmaking and watch repair here, so I wouldn't be surpised to see more of us here!
A recent frustration if anybody has a suggestion, is wrangling the fiddly clip on dial-guard on a Hattori VX32E movement. I just can't get that sucker back on there. I can't seem to get the tiny little clips into place!
All the best,
Sebastian
Hello, plenty of info for you on here, sometimes its best to post a picture of what you are having problems with. It helps those on here as many are beginners, so they won't have come across what you are working on, it also helps them in giving there ideas to solving the task. Looking forward to your input on this friendly forum.
Hello Sebastian and welcome,
Marks videos are what brought a lot of folks into the forum and are worth looking at. The guides start at the basic levels and will work up to more complicated levels in time.
I am not familiar with that movement and OH is spot on about the pics, I am fairly confident that someone will know something or failing that with a few pics you will get some advice from someone that has had a similar problem.
Working with a bit of peg wood in one hand to hold items down and tweezers in the other hand can sometimes be useful but that is a complete shot in the dark from me.
look forward to seeing how you get on.
Cheers, Vic
Edited by Vich
Welcome to the forum Sebastian. Maybe you can get a hold of Lawson by PM? I haven't seen him around recently. He is your countryman and very good at this. I'm not familiar with the movement myself so I wouldn't know where to start...all I can say is pegwood whittled properly and maybe even rodico to support your tweezers (well dressed) are your best friends for springs...in general. Of course, a specific moment might need a particular extra trick or two for a successful restoration.
Cheers,
Bob
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
