Screwdrivers Choices
47 minutes ago, jdm said:
I don't know if mine are VOH or not, but they say made in France. They're not as expensive as Bergeon.
JC
Going by price (three times as much) VOH is supposed to be "better" than Bergeon. But I'll probably never know first hand emoji1.png
VOH seem to be one of the best out there, but price wise, -- and during my searches -- I can't seem to tell the difference in price from, let's say Bergeon et al, plus or minus a couple of dollars (not much), so I didn't get them. The French option is more in accordance to a quality product that is at the same time a much less expensive option. I still went the Bergeon way but also own a couple of French ones and I'm not complaining at all.
I have ordered recently a couple of Beregeon 30080  screwdrivers from Cousins. To my surprise I found them quite different from those I use from many years. First of all they do not fit to my Bergeon rotating stand. The small ones have now handles of larger diameter. They are also heavier than the former ones.
Old design at the left, new design at the right
Surprisingly it makes quite a difference in using them, particularly the small ones .
It seems that Bergeon has silently redesigned  its most popular screwdrivers in order reduce the manufacturing costs. Now there are only three sizes of handles depending on size of blades instead of six in former design. Be aware of that.  You need the new stand and time for getting used to this new design.
I looked through several Beregeon distributors. They still have old and new design. Since there is no way to distinguish old from new by part number (they all are 30080), it may happen that when you place the order for few different sizes, you will get mix of old and new. That will be really confusing.
  • 2 months later...
On Friday I received my new set of Horotec screwdrivers.
I'm very impressed with the quality of them, but the real point of this post is to let people know that if they are after new Screwdrivers that Eternal tools
https://www.eternaltools.com/
has them for £27 cheaper than Cousins if you live outside the EU.
I'm assuming its because they have old stock, but if you are after new screwdrivers you may want to visit the above website to grab some before they sell out and I'm guessing at that point their price will go up.
I don't think this breaches the forum rules mentioning a website that has the best price for a certain tool, but if it does happy for the post to be deleted. Cousins gets most of my money, but Eternal tools was definitely the best place to buy my new screwdrivers from.
If those a Indian, run, do not walk away... I bought a set of Indian screwdrivers and I knew better...Why I did it I don't know. I still have them, and when I am depressed and need a bit of cheering up, I bring them out and compare them to my Bergeons. Soon I am laughing so hard I am no longer depressed. :)
It's all good to save a buck where possible...Indian screwdrivers are not the place to save.
Ron
You can always buy Horotec or Bergeon replacement blades for less expensive holders. Check out Otto Frei and Esslinger to get a price range on these items. If your budget will permit you can pick up a set of Horotecs with the ball bearing holders for about $150.00. I have seen the prices of screwdrivers  range from less than $10.00 to hundreds of dollars for a set. The number one problem with the less expensive sets is the blades are too soft. A high quality replacement blade will correct that and save you some money.
david
Edited by david
There are a lot of postings about Bergeon drivers of poor quality recently, however Bergeon makes at least 4 different types, perhaps more.
I have india made, Anchor brand drivers and they work perfectly, after more than 1 year I've replaced only one blade because I had damaged it myself.
One of my favorite watch restoration guru's is Steffen Pahlow. The screwdrivers he uses looks like he found them in a salvage bin at a pawn shop. I don't  think any two of his screwdrivers match. The important thing is the screwdrivers either turn the screws in and out or they do not. I have several sets, some are considered to be high quality and others are not. It is probably more about what you are used to then anything else. I have removed many screws with my el cheapo's and they work fine. I have removed screws with my Horotec's and they work fine. The Horotec's are extremely well made and do not have any wobbly components. The blades are perfectly centered in the holders and are high quality blades. That said, there is nothing wrong with the less expensive screwdrivers. The are not as beautifully made but they work fine.
david
I am interested in buying this set of screwdrivers from Watchtool.co.uk, but i have read that the website has many bad reviews. I really like the screwdrivers and base for the price and I haven't been able to find it elsewhere online. Has anyone ever had a problem with this site shipping to the U.S.? or has anyone ever purchased these screwdrivers and has a good review? Any input is appreciated.
http://www.watchtool.co.uk/switzerland-189770-screwdrivers-stand-p-7762.html
I don't know if it would be worth it to buy from UK when you have to pay shipping to US. Have you tried Esslinger?  They have watch tools at a reasonable price and they are in the US.  I've bought from them many times and I've always been satisfied.  Just look up Esslinger.com
Hope this helps.
Shilrey
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
