Anyone know which clockmakers mark this is?
buzz12
The mark Foreign was a requirement UK's Merchandise Marks Act, 1926 which states:
In the case of goods manufactured or produced in any country, the word "foreign" and in the case of goods manufactured or produced in part of His Majesty's Dominions outside the United Kingdom, the word "Empire"; or the definite indication of the country in which the goods were manufactured or produced; the indication being given, in either case, conspicuously etc. etc.
Most German clocks tended to use this mark instead of the country of origin due to the strong post WW1 anti German sentiments at the time.
1 hour ago, buzz12 said:
Thanks for the Mikrolisk idea, Rogart. Didn't find anything in S, but a very interesting site.
Tried to upload a picture of the movement but it failed. Will try again later.
I found a very similar mark but it was not excatly the same? Schocken AG . Did you see that? Tried google it and found nothing :)
Ditto, great minds think alike, Rogart. It is on a triple train movement that I think came from a mantel clock.
Cheers Blacklab. So it might be German? Well that's some progress. The search goes on...
Just a thought ... if I was a manufacturer whose acronym included three S's then it could make sense to create a stylised logo that had three S's in one!
So we're after a non-British clock maker, maybe German, with potentially three S's for their name. I know Salomon, Siedle and Sohne and W&A Schmid-Schlenker for instance. Were there other 'foreign' makers with multiple S's?!
Undoubtedly a red herring but worth seeing if this narrows anything down! :unsure:
  • 7 years later...
    • Hi. Sounds like a problem clock, can you post some picture# of the clock and the parts in question please.       Thank you
    • The first broke while i was using a dremel to shape the jumper spring at the join, i guess you call it the fixator, the disk grapped hold and flicked it off . The second time same place but while i was filing.  This steel feels more malleable, it is annealed steel. Working out the detent on the jumper is a real. pain in the butt.
    • I'm trying to get a balance spring Mantel clock to run to time - even with the regulator set to Slow it's gaining 40mins a day (the balance spring was damaged on receipt so it may be shorter than it should be - can't think why else it should run fast, especially as it is quite dirty & apparently hasn't been working for some time.). Anyway, looking closely at the train I've noticed the pre-escapement wheel is slightly 'dished'. Could this have been done by a previous tinkerer to get around a problem that should have been addressed by e.g. bushing pivot holes?
    • Hi Rich, now i realise that you spring broke. how did it broke, may be when grinding the fixator part with the dremel? If so, then guess You have let it to vibrate free, this is wrong. One must keep the spring pressed with finger to boost the vibrations, other vice it resonates and breaks.
    • The movement is so called 'Tongji', standard chinese movement. The stem can still be used with the help of extender.
