Anyone know which clockmakers mark this is?
buzz12
The mark Foreign was a requirement UK's Merchandise Marks Act, 1926 which states:
In the case of goods manufactured or produced in any country, the word "foreign" and in the case of goods manufactured or produced in part of His Majesty's Dominions outside the United Kingdom, the word "Empire"; or the definite indication of the country in which the goods were manufactured or produced; the indication being given, in either case, conspicuously etc. etc.
Most German clocks tended to use this mark instead of the country of origin due to the strong post WW1 anti German sentiments at the time.
1 hour ago, buzz12 said:
Thanks for the Mikrolisk idea, Rogart. Didn't find anything in S, but a very interesting site.
Tried to upload a picture of the movement but it failed. Will try again later.
I found a very similar mark but it was not excatly the same? Schocken AG . Did you see that? Tried google it and found nothing :)
Ditto, great minds think alike, Rogart. It is on a triple train movement that I think came from a mantel clock.
Cheers Blacklab. So it might be German? Well that's some progress. The search goes on...
Just a thought ... if I was a manufacturer whose acronym included three S's then it could make sense to create a stylised logo that had three S's in one!
So we're after a non-British clock maker, maybe German, with potentially three S's for their name. I know Salomon, Siedle and Sohne and W&A Schmid-Schlenker for instance. Were there other 'foreign' makers with multiple S's?!
Undoubtedly a red herring but worth seeing if this narrows anything down! :unsure:
  • 7 years later...
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
