Balance Staff Pivot Length
I have a Rone pocket watch balance with both pivots broken off the staff which currently measures 5.8mm. Looking at the jewels either side they're both recessed into the metalwork on both sides also which I'm going to have to look at but I'm trying to determine how much to add on for the pivot lengths. What figure would be realistic? 0.2mm each? It's quite easy for me to guess but with these very small measurements it's difficult for me to grasp it well enough, whereas with an inch or a cm it's easy.
I would do the following. Take off one of the cap jewels. Put a thin wire through the hole jewel under it all the way down to the opposite cap jewel. Then bend the rest protruding from the hole jewel or mark the wire with a thin blade. Pull it out and measure from the end of the wire up t the mark/bending. Add a bit to this to make sure it will bi a tiny bit longer. It is better if it is longer, since one can file down from the length and then it will fit perfect. If it will be shorter, one can tilt the balance cock to set the correct endshake.
Couldn't find any markings on it other than Swiss made. I tried a single strand of electrical wire but that was too big but I got there in the end by removing jewels and some other bits as prompted by szbalogh so thanks. It's only a 7 jewel watch movement  but it looks nice and was bought as a gift to keep me busy.
Out of curiosity why do you need to know the length of the balance staff?
So as stated above there are reference books on balance staff dimensions including the length usually what I've seen is for American pocket watches although one of the books does have some other non-American pocket watches. So for instance the book American Watch Balance Staff Interchangeability. You can usually find this is a PDF available on eBay. but in the size range are looking for almost all are American. then usually when you're looking for balance staffs you need more than just the length you need the other dimensions.
So probably not of much use I am attaching a image of what the pivots should look like it's not really overly helpful for the length.
Then googling Rone pocket watch reveals quite a few so it would help if we had a picture to narrow it down. It looks like they probably didn't make their own movement so it's possibly somebody else's depending upon its age we might be able to figure out what it really is perhaps.
  • 2 years later...
I'm working on Cupillard 233 movement. It has a broken balance staff at the balance cock end. It also has broken staff jewel which I need to replace. I bought a balance wheel complete from cousins for the 233 but it is a tad too long. How can I make adjust to the length with out damaging the new staff? All advice is welcome.
Dear mistergrumpy.
Show close up pix of the movement on this thread. if not identified,
Poast " identify this movement" in appropriate forum.
Avoid long threads, hard to joiin in or survive the endless discussioons.
Balancestaff.com and Dr ranfft and other database provide some details.
Regards joe.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
