  • Similar Content
    • By eccentric59
      I'm as green as they come and need a scrap movement for practice. I scored this on an eBay auction for $0.99 (+ $4.99 shipping, LOL) First inspection shows it not in terrible condition. The balance and escapement move at least, but it doesn't wind (very stiff) and the keyless works are either rusted fast or broken (the stem does not move in or out). I'll be taking this very slowly, since it's educational more than anything else.
      Please note the high quality cardboard case ring.
    • By east3rn
      Hello.
      I am now working on a vintage "trench watch" movement from 1910s that I mentioned before with a question regarding identification of the movement.
      (I still haven't got the exact ref. of the movement.)
      As I was disassembling the movement, my screwdriver slipped and broke one of the parts that function as a spring for the click.
      I tried looking for replacement but I am not sure what I should look for.
      Also, one of the jewels on the  wheel bridge is broken so I need a jewel as well.
      Could anyone advice me on how to find the correct part for click spring and the jewel for the wheel bridge??
      **Could the click spring be put back together??
      Thanks. You are always of great help.
    • By trevsdad
      I'd like to try my hand at converting a vintage pocket into a wristwatch.
      For anyone who knows, what size pocket watch should I aim for and what's the best source for an appropriate sized case? Is a 'Hunter' best for this? What's the best solution for a winding stem and if I have to go with a case that's not drilled for the stem, what's the best solution?
      In other words, what best practice for this mod?? Any help would be appreciated.
      thanks
    • By Dave84
      Hi Everyone
      I hope you are all well.
      It has been 12 months or so since I last logged in, and shamefully about the same since I pulled out my box of old watches. I was browsing the 'Bay' as always and really liked the look of this Waltham Traveler. I picked it up for less than £10 and would like to use it as my first restoration project. I have undertaken minor repairs in the past but nothing like this, I hope I haven't bitten off more than I can chew.
      I need to find a key to see if it winds & runs, repair/service it and source the hands and a case, which is uncharted territory for me and I'm not sure how easily they are sized / sourced.
      Any help, advice or pointers that you guys may be useful to me will be greatly received
      Many thanks in advance
      Dave
    • By AdamC
      It's been a while since I've worked on a movement as old as this. A friend asked me to look at whether I could get his great-grandmother's watch working again. When I first saw it, I thought it was an old 1920's ladies wristwatch, though thought it odd that the winding stem is at 12. However, on closer examination, it resembles more of an old pocket watch movement. Now amazingly, the watch is ticking when wound but I cannot pull the stem to set the hands. On removing the dial, I can see the yoke and yoke spring on the opposite side. But would I be right in thinking that it is missing the setting lever? There is a space that looks suspiciously like there could have been a setting lever there once but I could be wrong.
      I'd also be interested to hear your opinions on the age of the movement. I'm thinking around 1900.
      What's more surprising is that when the case is closed, you don't see the chipped porcelain around the edges, so thick is the bevel. It looks so nice and ornate and when the case is closed. Would love to be able repair but have my doubts.
      Any ideas about the keyless works?
      Thanks in advance.
    • I believe that both evaporate very quickly. As far as I understand it (I don't use either), they are both either dry lubricants in a highly volatile carrier, or the lubricant portion of it is extremely small so it has to be applied using a carrier to bulk it out for handling purposes. Either way the carrier solvent is designed to be very volatile so that it quickly dries after application, leaving just a very light coating of the actual lubricant behind. Pretty much the same as the old school "couple of drops of 9020 in 10ml of benzine" trick that @nickelsilver alluded to above; the benzine evaporates leaving behind just the lightest application of 9020 residue.
    • Rogart63 reported lubeta having disappeared from the bottle he had, dispite the lid tightly.preesed on. Was it through  EVAPORATION? Dose lubeta v106 .evaporate?   I guess v105 dose not.
    • Thank you for your introduction and welcome to this friendly forum.
    • Thank you for your introduction and welcome to this friendly forum. Lovely country  Norway.
