11 minutes ago, nickelsilver said:
In my experience with stones (quite a bit) a hard Arkansas would take ages to reshape a chipped or damaged screwdriver blade, and put too fine of a finish on it. In both the schools I went to in the U.S. and Switzerland we used a medium India stone. But whatever works- everyone has their preference.
This. I use an €2 aluminium oxide slate and it works equally well for my cutlery,  lawn mower, and watchmaking screwdrivers.
Edited by jdm
Link to post
  • Replies 185
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I spent the day literally watching paint dry. I was using black lacquer to fill in the engraving on a pocket watch case to make it stand out. I will send pictures when it is finished. In the mean
This should put your mind at rest. Click on this link. http://members.iinet.net.au/~fotoplot/sdriver/sdriver.html
Like others on here I don't restrict myself to just one set of screw drivers. I have one set ground to a thinner profile, and another set ground to a slightly fatter profile. I also have numerous scre
Posted Images
I pulled this off of the internet:
An India Stone is made from the man-made abrasive aluminum oxide. The term India Stone is a trade name for Norton's Aluminum Oxide sharpening stones. Norton's India stones are orange, tan or brown in color. This distinguishes them from Norton's Crystolon (silicon carbide) Stones which are gray in color.
Link to post
  • 2 months later...
On 12/15/2019 at 10:12 AM, david said:
I use waterstones to sharpen woodworking tools such as various cutters and chisels. They are unsurpassed in this application as they are made from a softer material, designed to wear quickly, and will put a mirror finish on a chisel blade. This however is not the goal when shaping a screwdriver tip. Old Hippy is correct in selecting an extremely hard oil stone such as an Arkansas stone. The purpose is to shape the screwdriver tip with the stone, not the stone with the screwdriver tip.
david
I'd agree as well.  I have some beautiful water stones and if I put a screwdriver near them they'd be damaged.
I use aluminum oxide stones for sharpening screwdrivers and just do it under a microscope.  Even with the harder stones you can easily gouge them or otherwise make the surface uneven.
Link to post
Having just finished a run of four or so Bulova movements (also known as a run of bad luck) with their attendant TINY slots, I would love to be able to find a way to make hollow grind tips work in them .  I can't seem to ever get a hollow grind small enough to reliably fit these **BLEEP** screws.  Maybe its just me.
RMD
Link to post
     No,  its not you.   all the new screw drivers are flat.         my secret:    use round hone stones on the flats.  AND its not that important.   just  buy  good drivers.  vin
Link to post
If you use the correct size screwdriver for the job and hold the screwdriver in the correct position the screwdriver should't slip. Many do not use the correct size, not only will it do damage to the screw but also to the movement.
Link to post
7 hours ago, lxt123 said:
One trick I learned is not to use the Arkansas stone. I prefer to have very fine vertical ridges on the tip, as the grooves prevent horizontal slippage.
Just a passing note, we have a section in this forum where it's considered polite for new members to introduce themselves.
Link to post
This is a different issue
  • Confused 1
Link to post
Hi,
    I'm just starting out repairing watches and have found an old set of screwdrivers that I'd like to use. However, a couple of them have chips in the tips. Is it possible to repair the screwdriver tips using a grind stone or should I just buy a set of new tips? I've attached a couple of pictures that show the damage.
Thanks
PJ
Link to post
Bore da.
Have a gander at the following to give you an idea :-
There are others on there that illustrates, some by members of this forum.
Take care.
Sent from my moto g(6) play using Tapatalk
Link to post
Your blades have been hollow ground on a tool like this.
If you use the tool illustrated by nad you will have to flatten each side of the tip. You should replace the blades or buy the hollow ground sharpener.
Link to post
Hi Watcher
OP's pic's of his blades don't look to me to be hollow ground.
Perhaps you could enlighten us with your observation of the need for that particular tool?
Thank you.
Link to post
9 hours ago, nad said:
Bore da.
Take care.
Thanks for all the information. I've ordered a grindstone and one of the tools in the video above. Will have a go at repairing the tip once evreything arrives.
PJ
Link to post
Maintaining screwdriver tips was traditionally basic maintenance of tools. Usually new sets come with spares, and separate spares can often be bought.. I usually swap then occasionally have a session touching up a few of them. With non-magnetic screwdrivers the tips can last until there's a stubborn screw.
Link to post
8 hours ago, rodabod said:
Do remember that excessive heat will potentially turn your blue steel into softer steel!
They don't get hot at all with these discs.
I have to touch up tips nearly daily and no time for ruminant sharpening...
Frank
Link to post
Frank
daily? are you repairing 24/7?...:rolleyes:
Link to post
On 5/13/2020 at 11:21 AM, nad said:
Hi Watcher
Thank you.
Here is OP's blade shown with one of mine sharpened with the Horotec tool. To me they look alike. It takes just 5 seconds to sharpen a blade and then another ten seconds to deburr (a most important operation).
Link to post
    • I bought this for my new watch bench. It is nice but because of the way you work on a watch bench, the lamp is mounted on the same plane as your work space (this is higher than if it were a typical work bench).  As a result, the lamp cannot pivot upward enough to get optimal positions. So, what I had to do was design and print an short extender that pushes the fulcrum of the lamp away from the manufactured pivot point.  This allows me more range of motion. I am pretty happy with how it turned out.
    • This purchase must qualify:
    • Please keep us posted though. It's a beautiful clock and well worth a bit of time and effort to get it back to it's original glory. Good luck!
    • Did a bit more today on my Hettich. I also mucked around with practising on the top plate from the second Hettich that I bought. The calico wheel can leave marks and I am being gentle. I am certainly not pushing the plate into the wheel. I could easily stall the bench grinder that I am polishing on. I am wondering if Hettich started to use a lower grade of brass? I still cannot polish the brass to a mirror finish. On my Hettich (older) I have had to emery one of the posts that supports the movement and after 600 grit then 1500 grit, straight to Tripoli on my stitched wheel, then green on the calico wheel and the post is spotless. Absolutely gleams. post has a steel nut on the top of it that was rusty and affected by the battery acid. It is now polished as best as can be done and then I mucked around with a bit of heat and have changed the colour of the nut which looks quite good now. It was black originally. I have done several jobs now by hand where a having a lathe would have been so much quicker. Have to get rid of the Esprit first. Then I might have a chance.
