Screwdrivers dressing
On 10/12/2016 at 12:23 PM, TimFitz said:
I spent the day literally watching paint dry. I was using black lacquer to fill in the engraving on a pocket watch case to make it stand out. I will send pictures when it is finished.
In the mean time I was looking for screwdriver sharpening stone holders on the net. The sticker shock was amazing.
So i said to myself, "Self" your only watching paint dry, make your own, you have a sharpening stone and some wood. So I made this from scrap wood while watching paint dry. I'm happy with it & it cost nothing. It is perhaps not as pretty as Bergeon but they have enough money. 20161012_110004 (Small).jpg
Nice sharpener.  Apparently, watching paint dry can be a productive use of our time.
Please don’t get fixated on hollow grinding. With our small gauge screwdrivers, to achieve a concave grind of correct geometry would require wheels of a few mm in diameter. A readily available small diameter dremmel wheel would effectively have a ‘flat’ circumference on the tiny contact area being sharpened. So, hollow grinding is in theory ideal, but not practical. I use a fine oilstone and 3 in 1. With practice I am achieving good driver contact and no screw damage.
  • 4 months later...
Gunsmiths have run into this problem a lot because external screws are decorative.  In order to protect the top edge of the screw's groove you don't want a tapered screwdriver or a hollow ground screwdriver you want a parallel ground screwdriver.  At the size you guys are working with this may be a moot point as Deggsie has said but it's valuable to know what you are going after.  Tapered and even hollow ground screw drivers can engage the top or leading edge of the notch which is it's weakest point, this is what causes deformation of the screw notch.  Ideally you want to engage the whole slot, or the base of the slot, not the top edge.
On ‎1‎/‎18‎/‎2018 at 6:40 AM, vinn3 said:
"carless jewelers' ?  I say - amateur  mechanics !  it happens in cameras also.  so, get your money back  and
learn how to sharpen a screw driver. vin
   it is quite sad to see a valuable watch, camera or clock.    with "upset screw heads"
   what ever it takes to get near 100%  contact in the screw head,  including the top edge.   another good subject is "restoring" screw heads.    vin
  • 3 months later...
you can also harden the tips. after heating them on your kitchen stove till they glow a bit, dip them in motor oil. this will increase the carbon content of the steel , hardening the surface. they seem to last a little longer between sharpenings.
I would be interested in that.
'Chewed' screwheads irritate me, I'm not set up yet to restore screws in watches, but its on my list of things to get set up to do.
Feel free to start a topic on restoring screw heads, I certainly would be interested.
I am going to try this.
   there is an excelent post on bluing screw heads someware on this forum.   the bad thing about it is buying a watch with pre "chewed" heads and having to say "I dint do it" !  vin
On 2/5/2018 at 2:07 PM, mhorlogerie said:
The best way to adjust drivers is with an abrasive stone. You can use a holder but it is also possibly to do it by hand. I prefer a Norton India stone, I have tried diamond stones and those work as well.
Norton stone ?  The very best.
7 hours ago, oldhippy said:
Sometime ago I went through how I would tidy up and blue screw heads for clocks. If you want that, I can go through that again. Just ask.
I know how to blue screws, but I am interested in how you get screws back to a state ready to be blued
  well,  put them in a lathe,  resurface them,  put them in a mill and enlarge the slot.   best buy new ones.  vin
Cleaning screws and blueing.
I cleaned clock screws up using a lathe, but you can also use a screw head polisher. Take the rough edges or burr off by using your needle files or small bench file. Then use various emery sticks finishing with the finest to produce a very fine finish. You then need to burnish the complete screw head. You then need to clean the screws; I used an old watch cleaning machine with old cleaner and rinse.
I used to blue the screws using an old copper penny in a hand vice which was over a spirt lamp (you don’t want a long wick) the hand held was then held in a bench vice. The trick is to blue all the screws to the same colour blue. If you fail, then clean the blue off and start again. As soon as the screw has turned to the required blue quench the screw in oil, this makes the screw shine. Clean the screws again in the cleaning machine, dry and cool. If you are successful, all the screws will be an even colour blue. It takes a little practise.
There are a few ways of bluing screws. My master taught this way me.
100% agree....but in the common vernacular, hollow ground is used to describe the resulting parallel, and desired, end you describe- i.e. the curve is a hollow vs the flat side of a regular screw driver.  Its what Wheeler and Brownels call them (this the set I have, and recommend it)  https://www.btibrands.com/product/professional-gunsmithing-screwdriver-set-89-pc/
I've do a lot of work on old machines and lathes (Schaublin 70's, Holbrook B8, rivett 608 etc) and a lot of these are put together with slotted head fasteners; some predate socket head cap screws.  Its really a shame to some of the nicest machines man's ever made scarred because some hack took a screw driver to them.  The trick is one  of those large gunsmith screw driver kits with hollow ground blades of different widths and thicknesses.  For stubborn ones you can put a wrench on the bit and it loosens without damaging the screw heat
Having said all that, I haven't weighed in on watch screws as (from lack of experience with watches specifically) I'm not sure of the necessity as it may be that the torque/contact ratios are different such its not required, and secondly the world best makers of watchmakers tools don't bother (although Bergeon does offer hollow grinding rig irrc) nor do many watchmakers who I view as highly competent.   I've a lot of books on watchmaking and cant' recall reading it (at least that I remember).  You'd think if it was important, given screwdrivers are the most used tool in this craft, tied maybe with tweezers, that if it was oh so important, hollow grinding them would be the first chapter in every book, yet it seems rarely or never mentioned.
bit of a zombie post.....didn't realize how old that one was :)
Edited by measuretwice
Hollow ground screwdrivers are really only of use if you work on the same model of watch all the time.
The reason is if your flat ground screwdriver is too thin you just stone a tiny bit off the end to make it fatter.
On a hollow ground screwdriver you need to remove a lot more material to make it fatter, and then hollow grind it again to suit the screw you want to undo, so its harder to swap between brands of watches that you need to adjust your screwdrivers for.
If you worked as an 'in house' watch repairer of an expensive brand of watches, and always did the same movements then hollow ground is the best, but for most of us that works on what ever watch comes our way the flat ground is best being a compromise between time taken to reshape screwedrivers and the risk to 'chewing' screws.
  • 8 months later...
Dear All,
My nice Bergeon screwdriver set was chipped after few watch services, was looking for a sharpening kit to repair them, but I soon realized I own a Lansky knife sharpening kit, so I pop the screwdriver blade out and give it a try, the results are very promising, see the photos, it's easy to use and versatile, comes with different stones, if I like, I can even use the ceramic stone to give it a high polish, and I can always use it to sharpen my folding knives, what do you think? Love to hear them.
Darak
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
