Screwdrivers dressing
11 minutes ago, nickelsilver said:
In my experience with stones (quite a bit) a hard Arkansas would take ages to reshape a chipped or damaged screwdriver blade, and put too fine of a finish on it. In both the schools I went to in the U.S. and Switzerland we used a medium India stone. But whatever works- everyone has their preference.
This. I use an €2 aluminium oxide slate and it works equally well for my cutlery,  lawn mower, and watchmaking screwdrivers.
Edited by jdm
I pulled this off of the internet:
An India Stone is made from the man-made abrasive aluminum oxide. The term India Stone is a trade name for Norton's Aluminum Oxide sharpening stones. Norton's India stones are orange, tan or brown in color. This distinguishes them from Norton's Crystolon (silicon carbide) Stones which are gray in color.
  • 2 months later...
On 12/15/2019 at 10:12 AM, david said:
I use waterstones to sharpen woodworking tools such as various cutters and chisels. They are unsurpassed in this application as they are made from a softer material, designed to wear quickly, and will put a mirror finish on a chisel blade. This however is not the goal when shaping a screwdriver tip. Old Hippy is correct in selecting an extremely hard oil stone such as an Arkansas stone. The purpose is to shape the screwdriver tip with the stone, not the stone with the screwdriver tip.
david
I'd agree as well.  I have some beautiful water stones and if I put a screwdriver near them they'd be damaged.
I use aluminum oxide stones for sharpening screwdrivers and just do it under a microscope.  Even with the harder stones you can easily gouge them or otherwise make the surface uneven.
Having just finished a run of four or so Bulova movements (also known as a run of bad luck) with their attendant TINY slots, I would love to be able to find a way to make hollow grind tips work in them .  I can't seem to ever get a hollow grind small enough to reliably fit these **BLEEP** screws.  Maybe its just me.
RMD
If you use the correct size screwdriver for the job and hold the screwdriver in the correct position the screwdriver should't slip. Many do not use the correct size, not only will it do damage to the screw but also to the movement.
7 hours ago, lxt123 said:
One trick I learned is not to use the Arkansas stone. I prefer to have very fine vertical ridges on the tip, as the grooves prevent horizontal slippage.
Just a passing note, we have a section in this forum where it's considered polite for new members to introduce themselves.
This is a different issue
  • Confused 1
Hi,
    I'm just starting out repairing watches and have found an old set of screwdrivers that I'd like to use. However, a couple of them have chips in the tips. Is it possible to repair the screwdriver tips using a grind stone or should I just buy a set of new tips? I've attached a couple of pictures that show the damage.
Thanks
PJ
Your blades have been hollow ground on a tool like this.
If you use the tool illustrated by nad you will have to flatten each side of the tip. You should replace the blades or buy the hollow ground sharpener.
Hi Watcher
OP's pic's of his blades don't look to me to be hollow ground.
Perhaps you could enlighten us with your observation of the need for that particular tool?
Thank you.
Sent from my moto g(6) play using Tapatalk
9 hours ago, nad said:
Bore da.
Have a gander at the following to give you an idea :-
There are others on there that illustrates, some by members of this forum.
Take care.
Thanks for all the information. I've ordered a grindstone and one of the tools in the video above. Will have a go at repairing the tip once evreything arrives.
PJ
Maintaining screwdriver tips was traditionally basic maintenance of tools. Usually new sets come with spares, and separate spares can often be bought.. I usually swap then occasionally have a session touching up a few of them. With non-magnetic screwdrivers the tips can last until there's a stubborn screw.
8 hours ago, rodabod said:
Do remember that excessive heat will potentially turn your blue steel into softer steel!
They don't get hot at all with these discs.
I have to touch up tips nearly daily and no time for ruminant sharpening...
Frank
On 5/13/2020 at 11:21 AM, nad said:
Hi Watcher
Thank you.
Here is OP's blade shown with one of mine sharpened with the Horotec tool. To me they look alike. It takes just 5 seconds to sharpen a blade and then another ten seconds to deburr (a most important operation).
    • Hi. Sounds like a problem clock, can you post some picture# of the clock and the parts in question please.       Thank you
    • The first broke while i was using a dremel to shape the jumper spring at the join, i guess you call it the fixator, the disk grapped hold and flicked it off . The second time same place but while i was filing.  This steel feels more malleable, it is annealed steel. Working out the detent on the jumper is a real. pain in the butt.
    • I'm trying to get a balance spring Mantel clock to run to time - even with the regulator set to Slow it's gaining 40mins a day (the balance spring was damaged on receipt so it may be shorter than it should be - can't think why else it should run fast, especially as it is quite dirty & apparently hasn't been working for some time.). Anyway, looking closely at the train I've noticed the pre-escapement wheel is slightly 'dished'. Could this have been done by a previous tinkerer to get around a problem that should have been addressed by e.g. bushing pivot holes?
    • Hi Rich, now i realise that you spring broke. how did it broke, may be when grinding the fixator part with the dremel? If so, then guess You have let it to vibrate free, this is wrong. One must keep the spring pressed with finger to boost the vibrations, other vice it resonates and breaks.
    • The movement is so called 'Tongji', standard chinese movement. The stem can still be used with the help of extender.
