  • Similar Content
    • By mousekar
      Hello All,
      I'm wondering what tool is commonly used to manipulate the regulator arm? I've used everything from tweezers to a plastic stick used to help open up computers. My main issue is that all of the things I've used are risky for slippage and I find it incredibly hard to just nudge a little when you're really trying to dial in the timing. I would think there would be a special tool for this (there's a special tool for EVERYTHING), but I haven't managed to find such a tool if it exists. Today I made my own tool using an old broken spring bar tool that I reshaped that should make life a little easier, but I'm very curious to see what everyone else is using.
      thank you
    • By PaulnKC
      All,
      I am very nearsighted (between -6 and -7 in both eyes). With astigmatism. Now, in my late 50's I also have significant nearsightedness.
      I thought a flip up visor - which I could wear with my glasses would be best. I purchased an OptiVisor with a flip-down loupe. But not happy at all with the visual quality.
      I know you get what you pay for in optics. What is the best type of device for someone with old-bad eyes.
      I have never used a regular loupe - but thinking that may be the way to go. Any of you guys (or gals) have a reccomendation?
      -Paul
    • By rduckwor
      If this is inappropriate, please delete the post.
      I have an acquaintance who is closing his shop due to health after 43 years.  He has a large quantity of parts, stems, crowns, crystals and all the paraphernalia one would accumulate after a long period in the business.  He needs to liquidate his shop.  This isn't a "Hey do you have a __ for a __." kind of post.  We're talking serious stuff here.  Mass quantities.   If you need parts, equipment, etc. for your practice, please let me know.  I will pass along his email contact  to you.  Obviously, this is useful primarily only to those in the U.S. due to shipping costs.  But he has a huge amount of useful goods and is 100 miles South of Atlanta.  PM me if you need something.
      Thanks,
      RMD
    • By BrianG1
      Hi, I have a few bits and pieces, and clocks. And I am very interested in horology tips, conunundrms etc.
    • By marcoskaiser
      Would it be interesting for this forum to set up a list where we could exchange things like parts and tools?  I happen to have duplicate tools from my lot purchases, and feel that those could be better used. No money involved. Would that be feasible?
    • Hi You definitley have an issue with the barrel/arbour, If you can remove the cap from the mainspring barrel and check on the condition of the spring its self it may be a contributary factor.
    • I usually end up trying every tool I think may work.
    • Thanks everyone for the great responses.  Hope I get enough time to practice being just hobbiest currently! Just my mobile platform. Chrome browser, Android O/S.
    • Thank you watchweasol. It took me a while to figure out how to the jam the train wheels and while I was trying to figure that out, I discovered the horn on which the pallet fork moves back and forth was bent and that did not allow the escape wheel to move further from the entry stone of the pallet fork. I managed to straighten that and tried putting on the balance but no luck. Then, I used a thin needle to try and jam the train of wheels and the end of that neddle was resting on the center wheel. In that state, when I tried to move the pallet fork, it was responsive and I could see it was allowing the escape wheel to move with corresponding movement of the other wheels. The moment I removed the needle from the 'jar' position, the escape wheel was no longer responsive. I'm still trying figure out what the issue is considering all wheels were spinning freely after I removed the pallet fork and tried winding the barrel.  Secondly, I did everything as you said i.e. Only put the barrel, ratchet and the barrel gear. After winding the spring a little, I tried to release the click spring but the barrel did not unwind. This is what I'm examining currently as I write this.  P. S. I manually unwound the power from the barrel by rotating the ratchet gear in the opposite direction till the point I could not rotate it anymore.
    • Hi,    Its been a long time since I posted anything but I've ran into an issue that's a little different. I'm repairing a Rolex datejust with a 1570 movement. The watch has been exposed to a lot of moisture. The date ring itself is discolored and paint is separating from it. I have obtained a replacement. Now the issue is the date seating ring has some rust.  Two of the screws that hold it in place were badly rusted but I was able to remove them.  The real issue is one of the tabs on the date seating ring that hold the calendar ring in place has rusted and is preventing the calendar ring from moving properly. I have looked for a replacement part and it is expensive and hard to find.  The ones I have seen seem like they might have the same problem. I was wondering if it is possible to knock out the rusted tab and replace it with something? There is a hole underneath the seating ring where the tab is so I'm assuming it is just friction fitted. Any ideas would be much appreciated, especially if anyone has dealt with this issue before. Thanks, Charles
