Proper amplitude for Unitas 6497
Nothing like getting some actual data so I have just put my own 6497's on the timegrapher.
I have a 1960's Le Cheminant pocket watch with an original 17 jewel UT6497 running at 18000bph which I have just serviced (last weekend). Still using original Ms and with the lift angle set at 44° I am getting 271° amp on full wind in the horizontal.
I also have a modern De Tomaso wrist watch with an Asian 6497 clone running at 21600bph. It's about 3 years old and I haven't serviced it. With the lift angle set at 44° I am getting 290° at full wind in the horizontal.
I would say that 240° at full wind was a little low for a freshly oiled modern movement.
Yes, like jdm said. If the rate is the same or within 5-10 sec/day difference in the different positions then its ok. Many thing can couse low amplitude. I suggest to check amplitude again after a few days. All the watches i serviced had different gain in amplitude after a few days.
Maybe i make something wrong :)
I assume you meant 6497-2 which runs at 21,600? So because I wasn't 100% sure I've attached the specifications for both the 18,000 version and the 21,6000 version timing specifications amplitude etc. You notice they only give a maximum amplitude not a typical running amplitude. The only way to really tell if what you have is right is to wait 24 hours and it has to be better than the minimum.
Then in real life you don't care what the amplitude is sort of. Normally people are more concerned about timekeeping not amplitude unless they're having a problem with timekeeping. What you want to look at is the isochronism number variation from fully wound until 24 hours later. If you're getting that who cares what the amplitude is?
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
