2824 keyless problems
AP1875
So this morning I serviced a Chinese 2824 I have. I completed it with no issues (or so I thought) and started to give it a good wind to check the power reserve etc when all of a sudden the keyless was just spinning freely when trying to wind.
I put it into the quick date change position and all ok.
I then placed it into the time setting position and it was ok.
So I took the cover off the keyless to check it out. I've found that when I put it into the winding position the sliding pinion is not moving close enough to engage the winding pinion.
I rebuilt it and now it will wind and quick date change but I can't set the time.
The yoke determines the movement of sliding pinion (which is seated correctly in the pinion).
What controls the yokes movement, it's as if it needs to push further?
Any ideas appreciated
So as I removed the spring this is what I see, the setting lever has jumped on top of the yoke. Now I don't know if this had happened as I've taken it apart but I think that would explain the reason why I can't set the time as the lever wouldn't be able to push the yoke/sliding pinion all the way back (please correct me if I'm wrong).
Now I just need to work out why this is happening, it should all be held in place.
Cover plate back on.
As it was in the wind position when it went back together, winding was ok. Moved across to date and time positions all ok. Tried to place back into wind position and the same problem - sliding pinion won't engage the winding pinion.
Ok, so when I adjust this screw for the spring that seems to affect whether it will engage wind or time set.
Tighten it right up - no wind function
Loosen it off - no time set position being achieved
It's half way between now and all functions work [emoji848]
Would this suggest the spring is damaged bent or something else to you guys?
(I'm really sorry this isn't all in one post)
(This is the screw I adjust)
It sounds like you may have over tightened that screw. remember we are working with very small tolerances here have you checked the setting lever spring to see if the plate around the hole has bent or deformed in any way causing it to pinch up to the yoke when tightened.
Look closely at the ends of the bridge screws (which screw in from the dial side) there should be a short one which goes where the yoke/ spring fits. if they're in the wrong place , the longer screw will stick up and interfere with the movement if the yoke.
HTH
Anil
HTH
Anil
This is a very good point, I didn't think of that. From looking at the picture that would be the screw just under the crown wheel. I think I have the correct screw but maybe when I tighten the screw from the spring right down it catches...
No need to hunt for a correct screw, Chances are its been swapped around. Remove them one by one and see if one is shorter than than the others, not only the barrel bridge but also the train bridge and balance cock screws as they're the same type.
rgds
Anil
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
