The Hatton watch
atimegoneby
This arrived in the post today I found it on Ebay listed as not working and got it for £3.10 plus P&P, I don't know what's wrong with it yet but it seems to be fully wound, hopefully I can get it going.
It actually looks better in real life than it does in the photo's, I think it takes a military strap as the lugs are fixed.  :)
Nice find. Dial and hands are in good shape and the case my clean up a bit so that the plating isn't quite so obvious.
It'll be interesting to see what's inside. Usually these things just need a proper clean and service to get them operational again.
let us know how it all goes.
I cleaned all the external grime from the case before opening it and here's what's inside,
and with a little gentle help with the pallet fork it started running !   it runs happily in all positions except dial up where it stops but quickly restarts when moved to any other position. I'll leave it overnight to run down as it was fully wound. :)
  • 2 years later...
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
