Allow Me To Introduce Myself My Name Is
Jimbayliff
Hi not sure if any one will help as I have got a very old clock here in front of me waiting for your help,know it is for watch lover this place but do not no any one to ask,when I got the clock it did not work or chime,but now I have got it working chiming at correct hour,but I cannot get it to keep good time when I got it working It lost 1.71/2 hours a day but now I put a new spring on the pendulum and oiled the pivot holes now got it down to 25 minutes a day so then turned up the pendulum but now cannot turn the screw any more so now do not no what to do next can any one help me,thank you
Hi Jim, if you've replaced the suspension spring check that it's the same length as the original, if it's longer that would do it, otherwise if the pendulum rod is at the end of its adjustment it normally means that the pendulum is too heavy, try changing it for a lighter one, hope this helps, Phil.
,and my name is Christopher thank you.
Hi Christopher, I think he called you Jim as it is Jimbayliff who started this thread ;)
To confirm: If you are starting a new topic then it's best to use the "Start a new topic" button which shows at the top of all the forum sections. I think you mistakingly clicked "Reply to this topic" hence the confusion ;)
Hi Christopher, sorry for the mix up, Smiths used several types of pendulums according to the movement used and the age of the clock but you should be able to modify the one you have, it sounds as if you need to raise the height of the bob, you could either just put some spacers under the knurled nut or cut some more thread onto the rod to give more adjustment, also make sure the clock is ''in beat'', Good luck , Phil.
Hi Phili,I have got spacers on the bob,if I change it the clock will not keep in beat like you say,as I got now it is keeping perfect beat with no problem,it is just the time keeping as I said I have tried lighter pendalums and it will not go I have tried adjusting it to it but it just with not work,i have tried lighter pendalum,but I have noticed when it is a wormer day it does run faster.thank you again for your help,I have been on this clock for about year I can say Maybe the main spring needs a new one maybe the spring is not on hard so is is slower so needs a new one I understand this is not a safe job to
Hi again,just thought about what you said and I put two spacers on on pendalum,I tried one and it make it much better so then after reading your mail I put a spacer on the offer end to take the middle out and it has had it very mush better,it is still losing about 5mins a day,I thought about adding more spacers,to correct it more,can I ask why it is so much out,can you help on more info abou it
Hi Christopher, the pendulum is probably not the original to the clock so it will be a case of adding more spacers, with trial & error you should be able to get it right, if you back off the knurled nut slightly it will give you some reserve adjustment in case you need it later on for fine tuning, hope this makes sense, Phil.
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
    • I need to see photos of the whole movement before I comment.
    • Hi @Jon, so, from one extreme to another the beat error is 0.1(min.pos) to 0.2(msx.pos), and as you mentioned the rate does up and down dramatically. Also checked the position of the collet, and the collet is not central to the jewel on the balance cock. Balance moves freely, per my understanding.   So, after 24h the ampl. fell down by approx 20 deg, which I would assume is expected. After adjusting the endshake I believe I gained around +10 deg. of balance movement. Which is great, and overall the balance is not at 220'ish deg.   What I did next, some might think is non-orthodox, but was wort a try. I too the mainspring out, checked again for endshake and if the pin moves freely, and cleaned everything. Usually when installing the mainspring I would use some barrel grease on the barrel walls, install the spring and put a 2-3 drops of D-5 oil on top of the wounded spring and in the places where the arbor sits. This time I took the spring and applied a ultra this coat of Molykote Dx paste on the whole spring, before installing it in to the barrel, and added some oil to the arbor as usual.  The result improved, at a full wound the balance produces about 230-237 deg. @JohnR725 I'm getting closer to 300 😃   What I am noticing, there is a fluctuation in amplitude. With time it would rise and drop about total 8-10 deg in an interval about 2 minutes. I assumed this ruled out the power transfer from the barrel itself. So I took the gear train out, cleaned and lubed.
