Upcoming Projects...
DJW
So I finished this build...mostly! I'm thinking of it as a "proof of concept"...
I decided not to do anything to the dial other than drill the markers at the hour marks, larger markers at the 12, 3, 6 and 9. This actually proved a problem after I remounted the dial and noticed that because the centerwheel pinion is off set from center, the minute and hour hands don't quite line up with the markers...not a huge deal though! Having said that, I think the dial looks Wonderful as it is! The simple dial/ markers really complements the "Busy-ness" of the skeleton movement.
I also had to turn a back "Dial" to make up the difference of between the size of the movement and the size of the exhibition back crystal. This picture looks "deformed" but actually was taken at an angle to capture the best light.
All in all, It will be something I do again now that I have an idea of what problems can and will arise when combining parts that were not designed to go together!
Edited by DJW
You've absolutely nailed that one Don, that really is one of the best looking watches I've seen.
I could happily wear it any way round because the rear is every bit as nice as the front!
Edited by Geo
Thanks Geo! I think next time I'll use the rear dial to actually aid in holding the movement in place. Right now, it is just cemented to the case back. Also,You should see the "Engineering" I had to come up with to hold the movement in place! No less than 10 individual pieces to secure it!
This is very nice I like it. The combination of the components complement each other perfectly. May I ask where you get your cases from. I have couple of projects on the go at the moment and am struggling to find the right style case. The case on this watch would suit my needs i think.
Hi Carl, here is a link to the page where you can purchase these. If you sign up for a wholesale account, you get a good discount on the price. It does not cost anything to sign up.
http://www.dajiwatch.com/productshow1514.html
That`s one of the best looking watches I've seen. I would start building number two because number 1 will soon be sold.   :thumbsu:
Thanks autowind!
I think I'll keep this one! I know I say that about all the watches that I say I'm going to keep, but its time I need to actually wear something that I put together. But, I am going to order movement number 2 this week!
Edited by DJW
  • 4 weeks later...
  • 2 years later...
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
