Pacific to Baltic train
Just did Shanghai to St Petersburg by train.  Not for the faith hearted,  but never the less,  a bucket list item.
I wore a Longines Conquest GMT for that one.
Shanghai to Beijing on a high speed Chinese train.  Beijing to Moscow on a rather slow (6 day) train,  then Moscow to St Petersburg on a Russian high speed one...
Very interesting indeed and not that expensive.
We want Pictures and Stories!
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
