my new project big one
I prefer the second option. Crown has to be on the right for me!
"Chunky" lugs are very popular right now, whereas lugless cases remind me of 1970s styling. If that is a bronzed case, then also popular right now. Not sure about the yellow dial - I'm a fan of the Tudor black bay bronze with a brown dial.
If you would like me to do some field reliabilty trials for you, then please let me know :thumbsu:. I wouldn't make any charge for this service...
Is this an auto, manual or quartz movement? What kind of selling price are you thinking of??
S
Stuart, crown in the right is not a problem, I rotate case and adjust dial on fit, movement ETA 2824/2 automatic, also color of dial i can do all colors.
What about : " If you would like me to do some field reliabilty trials for you, then please let me know . I wouldn't make any charge for this service... " are you watchmaker ?
For JDM on the rendering i don't put second hand but in the watch i put it .
Sorry to confuse, no, not a professional watchmaker, was just offereing to wear one for a few months to make sure all is ok in the real world.  My version of a joke, which sometimes doesn't translate well I guess!
S
  • 1 year later...
  • 4 months later...
  • 4 months later...
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
