Waltham pocket watch
Here's on for you all, I saw this on eBay, some of you who are interested  in pocket watches might have seen it too.
It was listed as a non runner,  he did not know what metal it was made of, i   have posted to picture as it was , who has any ideas,
From the picture as bad as it was you can tell a lot, there was a date engraved on the back if the watch.
I was looking at this, or very similar, just a day or two ago... also out-of-focus photos. I get a little skeptical when an eBay seller that's been around a long time posts such bad photos. Makes me wonder, especially when photos for his other items are pretty good. I would ask him to post better photos - if he doesn't, I would move on to other items. Just my opinion.
    • Welcome to the group Stirky. You can search for just about every subject in the craft here. Don't be afraid to ask if you can't find the answer that may have already been covered ( some ad nauseum LOL ). You don't have to buy Bergeon to get good quality. There are many decent mid-range tools available that will last you a lifetime. Cousins would be a good place to start . Cheers from across the pond ! Randy
    • I picked up a similar amount of these jewels some years ago in a watch and clock fair. Every now and then they come in handy. This week I've got a rubbed in bombe jewel in the balance cock that is cracked and needs replacing. Very handy to have a vintage assortment of these type of jewels!
    • Great diagram with the teeth and pinion count. Simple way to reduce the speed of the hour wheel by the 12:1 minute wheel. Genius and yet so simple. Always good to reinforce the principal by what you have done in your drawing. Keep doing that. I had a drawing on my wall for years showing me this which is very similar to the drawing you have done. Here's a formula to work out the beats per hour of a watch movement. The movement's BPH is dictated by the wheel teeth and pinion count and the hairspring being vibrated to the correct BPH by finding the pinning up point on the hairspring using a vibrating tool.  The reason in the formula there is X2 on the top line is because there are two pallet stones.
    • So I just wanted to say "thank you" again.  The angle is the key bit it seems and yes, it did basically just fall, or float, back into position when I got it lined up just right. I had meant to add that now that I see how it goes in, I totally see how it came out in the first place, and that whomever cloned the original movement didn't pay much attention to the fine details around the setting or how it interfaces with the balance cock or the "rings" on the regulator and/or stud carrier arms.
