Alternative to a staking tool set
TimFitz
I know repair tools are expensive & for me money is critical. So I would like to know if there is an alternative to those huge Staking tool sets I see for sale? I feel this is holding me back in my goal to learn as much as I can about watch making. Replacing a balance or jewels is an essential part of the trade. So what are the options?
Your opinions would be much appreciated.
Thanks
Well, instead of buying a set, you might try and find some individual pieces that are not that expensive to start. First, an anvil which can be as simple as a metal block with some holes in it. Better is an anvil that supports the punch and keeps it square to the work, I've seen serviceable ones sell on the bay for not much money.
Unfortunately,  the punches are very specialized, and I can't think of an alternative off the top of my head. They are, however, also available individually or in groups both new and used, and can be inexpensive if you are willing to clean them up yourself.
I was patient, and finally found a serviceable set used that I purchased for a bit more than $50, you can probably do better than that if you take your time.
My suggestion would be to download and study  material that @tomcolson has so kindly made available here -
http://kanddinverto.weebly.com/
and then hone in on the items you need to do the jobs that you have at hand.
this would be better if the price stays low I can only see the international shipping postage on it but it may be cheaper in America.  it has a revolving anvil with different hole sizes. You can also pick up punches cheap of the bay.
http://www.ebay.com/itm/Vintage-K-D-Watchmakers-Staking-Set-/282113586763?hash=item41af47b64b:g:fHAAAOSweXhXl1M1
I was also about to point out you can get vintage staking sets staggeringly cheaply, I got a bergeon star set, complete, with extra punches, in fine, precise working order for under £100, though I doubt I could get that good a deal again.
However, yes you can do a lot without the actual anvil and just get a staking block and stakes cheaply and easily.
ebay  ug !    ebay tools and delivery errors are even worse.    there is a need for a smaller, cheaper staking set.    a lot of those punches and anvils  can be made on a lathe.  use drill rod and then  harden it.   vinn
My situation is like yours. For a hobby i cant afford a complete set, although i am always searching for a cheap acceptable one. Currently for my 1-2 watches under repair i make my own stakes and tools. For me this process is just like as exciting as tinkering with watches.
Edited by szbalogh
I picked this up from ebay for a restoration project and I wanted one anyway, so the resto so far is going well.  All the holes in the box have a punch of some type, will upload images when it's finished.  It cost £33.00 or $43.00.
last 3 images are: rusted in box, after soaking in white vinegar, and soaking in 3 in 1 oil.
ebay is going to be your best bet. You can also try Uncle Larry's Watch shop. I bought my K&D 600 series for about a 100 bucks and had fun restoring it. Again, Uncle Larry's has a good selection of individual punches. One thing to watch on ebay is the sets that people are selling that are full of doubles or damaged bits left over from sets they buy to complete the set they already have.
A great way to clean up the stakes is to chuck them up in a cordless drill and use steel wool and then go to 1500 wet dry paper and finally use a quality metal polishing paste. Mine came out looking spectacular, much better than they ever did coming from K&D. The process is gentle enough that I did not change the diameter of the stakes. Use the appropriate caution around the business end of the stakes. You don't want to alter or round  off the ends at all.
Like yourself, I have to buy used and then spend the time to restore...some times I have just as much fun doing the restoration of the tools as I do using them...:)
As a veteran of a number of eBay staking set purchases, I concur with those above that it's a good way to get started. Complete sets in great condition go for top dollar but the prices for less complete sets requiring a little TLC are much more reasonable.
I started out using only abrasives to clean up the stakes as described here. Currently (today in fact!) I start with an overnight soak in EvapoRust to remove most of the rust and convert what's left to black iron oxide. Then I use fine 3M radial bristle disks to polish up the working and marked ends. I take great care with the working ends to insure that I do not round over corners, etc. Usually the highly polished working ends are the least rusted parts of the stakes.
I'm not a fan of vinegar for rust removal since it will remove clean metal along with the rust. EvapoRust or electrolytic derusting will not. An important note about EvapoRust: be sure to completely immerse the objects being treated. Any object breaking the surface will be etched along the waterline (deeply if you leave it long enough). One of my staking sets is very sad that I know this.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
