Chart For Watch Movement Sizes
I was going through my watch files today and thought I would post this handy chart of watch movement sizes in lignes, "Lancashire" sizes, millimetres and inches - just for reference if anyone needs it.
Watch sizes.rtf
Edited by WillFly
  • Like 7
  • 4 weeks later...
thank you will, sepasgozaram (persian).
I didn't know about movement sizes, thus I seach and find some more info that maybe useful for others:
A watch movement's size is gauged by measuring it across its center on the dial side through its narrowest point. This system is used by the U.S. Customs in determining the amount dutiable on imported movements, and thus it has become associated with the sizing of all watch movements brought into this country. Although the use of the millimeter to determine watch sizes is growing steadily, the predominant system still in use is the LIGNE. The LIGNE is equal to the twelfth part of the French Inch, which is approximately 1/16th larger than our own inch. One French ligne=2.25583 or roughly 2¼ mm. Thus a 10 ligne movement should gauge 22.5mm. In inches this would measure .8881 as the LIGNE is equal to .0888 parts of an inch. (Note: These days, movement sizes are more commonly stated in millimeters - Rob )
The SIZE as a gauge with which to measure movements is still used by some of the older American watch manufacturers to indicate the dimensions of their movements. The SIZE as a unit has its basis in the old "0" size movement. This movement measures 1 5/30". A difference of 1/30" accounts for each size smaller or larger than the starting point of the system, the "0" size watch movement. Thus a "1" size movement would be 1 6/30", a "6" size movement 1 11/30". Watch movements smaller than the "0" size are designated by adding zeros to the size. Thus a movement one size smaller than the "0" would be a 2/0 size movement and would gauge 1 4/30", the 3/0 size would then measure 1 3/30. Conversely, the "25" size watch movement would measure just 2 full inches.
A good way to remember sizes of the American and Swiss gauges is to associate the unit we know best, the inch, with both the American and Swiss equivalents. For example, the 6/0 size American movement is exactly one inch in diameter ("0" size = 1 5/30" - 5/30" = one inch). Also, the Swiss 11¼ Ligne is just a few ten thousandths of an inch under one inch, and can be called a one-inch watch movement.
ref: http://people.timezone.com/library/workbench/workbench631691117422306218
and :
Although the use of the millimeter to determine watch sizes is commonplace now, the predominant system still in use up until the 1960's and even to some extent in the 1970's, was the LIGNE. The LIGNE is equal to the twelfth part of the French Inch, which is approximately 1/16th larger than our own inch. One French ligne=2.25583mm or roughly 2¼ mm. Thus a 10 ligne movement should measure 22.5mm. In inches this would be 0.8881 as the LIGNE is equal to .0888 parts of an inch.
American watch manufacturers used to indicate the dimensions of their movements, by means of their own unique "Size" gauge. The "SIZE", as a unit of measurement, had its basis in their old "0" size movement. This movement measures 1" + 5/30" in diameter. Each difference in diameter of 1/30" accounts for each size smaller or larger than the starting point of the system, ie. the "0" size watch movement. Thus a "1" size movement would be 1" + 5/30" +1/30", or 1"+ 6/30" (or 1.2") and a "6" size movement would be 1 + 5/30 + 6/30", or 1 + 11/30" (or 1.366"). Watch movements smaller than the "0" size are designated by adding zeros to the size. Thus a movement one size smaller than the "0" would be a 2/0 size movement and would measure 1" + 5/30" - 1/30", the 3/0 size would then measure 1" +5/30" - 3/30". Conversely, the "25" size watch movement would measure just 2 full inches. A very confusing system compared to the modern simple metric system!
ref: http://members.iinet.net.au/~fotoplot/tech/wmms.html
  • 7 months later...
Muchas gracias por compartir esta valiosa información.
He copiado los datos del texto enriquecido y los pasé a un documento de excely  le inserté una tabla.  Y entonces los llevé de nuevo a word y los exporte en pdf
Lo comparto con ustedes.
Un Saludo.
Gracias por la conversión de los datos a PDF, estoy seguro que los miembros se encuentra este muy útil. El foro va viento en popa y es s genial tener de entrada de todo el mundo. Skip hablar español, así que espero que el traductor ha trabajado bien?
  • 1 year later...
Can't f
On ‎06‎/‎11‎/‎2014 at 8:11 AM, clockboy said:
Ok looking through my files found this chart that I have made up over the years. It is watchmakers logo,s which I have found really useful when I need to identify and watch movement. P.S I use a Mac but the PDF does explained using the tool bar.
Watch maker logos.pdf
  • 5 weeks later...
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
