- Look mommy I made a mainspring flower.
"10, 9, 8, 7, 6, 5, 4... take a deep breath and exhale." Ok, I've calmed down, stopped swearing and I promise not to punch and walls.
Mainspring, my mortal enemy why do you keep taunting me?!
I feel fairly confident when it comes to disassembling and assembling any type of watch (not including chronos yet). But when I sit staring at that mainspring barrel a voice always whispers in my ear "- Let it be. It's probably fine. No need to disturb what need not be awaken." But I always ignore that voice, I'm a capable man after all, right? Oh the lies, the lies I keep telling myself..
I have acquired a set of three K&d mainspring winders type 123. They usually do the trick when it has come to old Hamilton movements such as the 980, 770 etc. The t-end mainsprings found in these movements are easy enough to reinstall with said winder (most of the times anyway). Automatics however, seems to be a different beast entirely. I have in the last week completely destroyed two mainsprings while trying to restore a Seiko Sealion. I mean, what's the problem? What is so different with the automatic mainsprings? You hook it up, roll it in, and pop it out in to the barrel. But no no, these mainsprings does not want to play ball. They twist and turn and eventually explode. Is anybody else using similar winders with automatic mainsprings? If so, how do you get it to work? What am I missing? Or should I just leave the mainsprings be? Only open Pandora's box when I know it's broken? What do you suggest?
Here's the mainspring flower I picked this morning.
I can't help on the auto mainspring issue, :unsure: pretty sure someone here will help. Just wanted to say your humor is spot on!
I fought for a good 30 min trying to wind it in by hand. But I couldn't get the last 5 cm in. When I unwound it I also noticed the mainspring had taken quite a beating from my on hands approach. So not sure I want to give that another go.
I have that style of winder + a Bergeon style the same as Mark uses. I found that with both of these winders the issue is releasing the arbour once wound. If the spring is a bit tight around the winding arbour then if not careful it will pop the spring out with the flower.
I found what really helps is to give the winding arbour a thin coating of either barrel grease or Vaseline. Then this really helps when removing.  Also slowly does it I have a very thin pair of tweezers that I use to keep poking the centre of the spring back as it tries to pop out when releasing.
There's a always that nervous moment when the mainspring is fully in the winder and you have to make sure it doesn't pop out when removing the arbour. But the problems start even before that. I am experiencing the mainspring twisting and turning while winding it. It doesn't wind up in a perfect circle like the others, it moves around between the walls of the arbour and the winder.
Could it be that the mainspring is not high enough for the winder? That the mainspring doesn't fit tight enough between the arbour and the inside of winder (not talking diameter).
I used to pull every spring out of its barrel, clean then refit by hand, as I could never afford the tools at the time, and didnt ever have any issue, even with auto-springs--Except one time-
A Smiths Enfield Clock-spring got away from me during installation and slashed my finger open quite badly down to the bone...
Havent done one for years, as I tend to collect Accutrons now so no Dangerous Mainsprings!...
Edited by Alastair
I have not encountered that issue. I find as you wind the spring you have to un-twist sometimes especially as it gets towards the end of it,s length.
Winding by hand I always found difficult & if wearing finger cots the finger cot would try and get in on the act so I just purchased the winder.
I'm really surprised how bad my experience with these last two mainsprings has been. I am ordering a new one and will just pop it in the barrel.
The next watch on my to do list is a Seiko cal 6139. I have already bought a new mainspring just in case. If I can't re-wind the old one I must clearly be doing something wrong.
I don't know about winders but if you place the spring into the barrel, and go around holding the coils in place with the flat of the tweezers, possibly using finger coats in the right hand, it will go in without much effort.
I tried winding it in by hand (without having watched any videos on it beforehand I might add). I couldn't do it today. I might give it another go in the future. I would much rather spare my fingers and use the winders though.
What type of winders are you guys using?
Trust me the spring won't jump. You only have to be careful placing the first coil, all the rest is straightforward. Seiko barrels have their own sizes and you many not find a winder that fits perfectly.
I didn't face any problems with the spring jumping, it just got too hard winding it around. I'm probably missing something with the technique. I'll see if I can find a video on how to do it.
The good thing about the k&d winders is that you can adjust the diameter. So the non-standard sizes is not an issue.
3 hours ago, B3stia said:
Here it is.
That's what I was telling you, first coil firmly in then others will follow. But let the flat of the tweezers do the holding work with the barrel on the mat, no need to hold iit hand.
Edited by jdm
I'll give it a go next time if the new mainspring doesn't pop right in. Thanks for the tips.
On 27 July 2016 at 1:55 PM, B3stia said:
Here it is.
I'm fairly new to horological adventures but a recently retired 72 year old with all the hassles of a shaky hand I didn't know I had and old age dim eye sight. In six months of learning I have removed and replaced two main springs in exactly this method. Whilst the first took a lot of patience to get started, it was thicker than the one demonstrated here, but it actually gets easier towards the end.
thanks a lot for those discussions and videos. I owe you a lot. Nearly gave up a few times.
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
