wall clock oil
matabog
Hello!
So after tinkering with watches I thought I gave it a try with a clock. How hard can it be ;)? First of all you don't need magnifiers :) Actually you need to take a step back to see the entire thing.
Basic questions, if I may: what do you use to oil these beasts? How do you take out and put back the mainspring?
Some photos:
Thank you,
Bogdan
Edited by matabog
You can remove the mainsprings by hand BUT be very careful them springs can do a lot of damage to you & the clock if they get away. RE-fitting is very difficult by hand. I highly recommend a proper clock spring winder. I use the same machine as in the demo vid below. Notice even with the correct machine they guy uses thick gloves. I use moebuis 8030 which is for small to average size clocks. Looking at your pics the pivots look Ok but check the pivot holes for wear. If significant wear they will need re-bushing.
I always used windles clock oil. Its one of the better oils and can be used with most movements including Long case clocks. You need a clock mainspring winder, I used a boxwood mallet, hit the back of the winding arbor and the cap will come off, then use the mainspring winder to take out the spring. You can get the cap off by putting a screwdriver in the slot of these barrels, not all clock barrels have slots, you can take the spring out by hand but you will distort it, the same for putting it back, but it is not recommended because when you come to wind the spring up you will get an irregular unwind and it can effect the time keeping.
What you have is an 8 day ting tan movement sometimes called bim bam, I can tell by the three hammers, and it has an anchor escapement .
I am a hobbyist mainly interested in watches, not clocks. This one is just for fun. I wish a I had the means for re-bushing, though I believe this is not the case. I wish I had a winder, but I don't, so I think I will clean the barrel arbors only (naphta and Rodico). The mainsprings don't look too dirty.
I have another problem though - during the disassembly, one of the click-springs broke. Do I need to replace it or can I put a resort spring instead (between the hole in the main plate and an eventually future hole in the click)?
Or is that a BLASPHEMY?
Thank you,
Bogdan
I see by your photo you could have taken out the barrels without taking the whole movement apart. That type of click spring should be available from good clock part suppliers. If you decide to make and adapt a part just make sure it is strong enough to work and hold the click without too much give because if it slipped while winding it will damage the hand of the person that is winding it, broken fingers come to mind. Put a little grease around the click and don't forget to oil the springs and arbors, a little oil in the privet holes, anywhere that to metals meet and touch, a little on the face of the pallets is a must.
oil, oil, oil... I am used to and know the oil for a wrist watch. I don't know them for clocks - clockboy said something about 8030 - I suppose it is ok for the train eheel pivots. Is it also ok to use on the mainspring and pallets? It seems unlikely.
Anyway, I just bit the bullet and cleaned the mainsprings. I just took them out and put them back by hand - that was a workout, I'm still shaking a bit :) I cleaned them with a piece of cotton with naphta on it. They look much better now. I just need to oil them now - I suppose it is like for the watch mainsprings - just put four drops of oil  on the MS and two on the top and bottom of the barrel - but again, what type of oil?
Also, I am still thinking about the click spring solution.
Bogdan
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
