One of these days…
buzz12
Could anyone give me any idea of date for this case?
Yep it looks very rough now, but one of these days I would like to restore it. The case work I can handle and will enjoy.  Need to source some replacement handles and make a replacement door unless I find the original among my clutter.  But, what sort of movement and dial would this Chime clock have had?
Any info about the date/style would be greatly appreciated.
Could you give me the measurements. Height  of the case, width, width of the inside and and diameter where the dial will fit.
I can tell you it has been altered inside at the bottom where it has been looks like chiseled away in order to take a movement with a different pendulum.
Yes it has been altered at the bottom. The case stands 11 5/8h and is 8 1/2in w.
Inside is 9 1/4h x 5 3/8in w and the dial hole dia is 4 3/8. You will see from the picture that the dial hole is also rebated. Is that common or to suit a particular dial?
What gives it away for me is the two brackets with screw holes. A French movement strike on a bell not gong. I can't see a hole in the bottom of the case where the gong would be fixed.
Something like this. In this photo you can see the two fixing straps.
That's super Oldhippy. I've had a dig about through my movements and come up with this one. It appears to be the right size but is it the right sort of age as the case?  Looks to be a lot earlier to me, at a guess. What do you think? What style of dial would you expect to see?
I would say that case is anything from 1920's to 1940's. If you unscrew the bell you might find a stamp mark with the name of the maker and it might include a date. That nut for the bell is not the original. Also you should see two sets of numbers I set is for the length of the pendulum it is down in the Pouce & Lignes system it's an old French measurement system. The other set of numbers are for the pendulum, the original pendulum will have the same set of numbers. Your movement is an 8 Day Count wheel strike, the hands are of the  spade style.
Amazing stuff... you should write a book Oldhippy before you forget all this intriguing knowledge. Thanks for the pointers, it makes researching things so much easier and enjoyable when you know roughly what you are dealing with. There are two stamp marks but not found a date mark. Which set of numbers are for the length of the pendulum?
The number at the base is the one 7 2. You have the makers name which I can't make out in your photo. If you can get a copy of Watchmakers & Clockmakers of the World - Brian Loomes  you should be able to find the makers name and dates of manufacture.
19 minutes ago, ro63rto said:
I can see
ETABLISSEMENT MIROY FRERES
DE PARIS
and
Vincenti & Co
Copied into English ESTABLISHMENT OF PARIS VITA BROTHERS
Vincenti & Co is listed as around 1910.
I would have thought it would be older.
Thank you ro63rto for the information. My eyesight is hopeless these days.
  • 3 years later...
12 hours ago, oldhippy said:
JimmyD, Did you ever find out about the clock, the one where the key holes didn't line up?
I sent a 2nd email asking them again and did not get a reply, so I did not send anymore, however after further research it seems that it was common for the key holes to be offset. I still find it odd that a maker of his stature did that though.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
